Glossy vs Matte TV Screen
  • fredrock46
    • May 2014
    • 22
    I just want to know what TV specification indicates if the screen has a glossy or matte fimish?
    I have a Vizio 42" TV with a matte finish and my sister has a similar 42" Vizio with a glossy finish. I like hers much better. I'm buying a new TV now and want I it to have a glossy finish but I don't know what specification to look for.
    Re: Glossy vs Matte TV Screen
    I guess it's preference but I prefer matte screens myself where possible. Plasmas naturally excluded due to the glass panel. The only way to be sure would be to see an in-store demo model.
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • paqman
      Vizio M60-C3 black screen
      by paqman
      So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
      So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
      03-02-2024, 04:37 PM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
