Panasonic TH-PX60U is completely dead.
  • ruatha65
    • Nov 2014
    • 12
    I have an issue with my TH-50PX60U. It is completely dead. No lights, no blinks, just kaput. I found a troubleshooting manual that Tom66 had posted, and it led me to either a bad P board or bad DG board. Here is the quandry, which board is it?
    At first, I thought the issue was simple (like you all haven't heard that one before!). My kids used the on button on the set often when the tv remote lost power, so i figured either the button itself had worn down or the switch board was bad. Button was fine, and I replaced the board, still no fix.
    I tested the power cord, the wall outlet and the transformer, all are good.
    AC relays did not click when power cord was put in, so went to step 2 on the troubleshooting guide, which was to test if either pin 1 of PA40 or pin 1 of HC22 had 5V. PA40 had 0V, but HC22 had 5V. The problem is, HC22 had nothing plugged into it.
    According to the guide, if I answer the "or" proposition above with a "yes" since one of the two had 5V, it's the DG board. If the answer is "no", it's the P board. My question is, does it matter that HC22 connects to nothing at all? Simply because it has 5V and PA40 has nothing, should I assume it's a DG board?
    I had added this post to another thread, and TW2005 suggested that I start a new thread for others with similar issues in the future. Since I'm a newbie and just now allowed to start threads, here it is.
  • ruatha65
    • Nov 2014
    • 12
    Re: Panasonic TH-PX60U is completely dead.
    To update a bit on where I am so far, TW2005 posted a thumbnail that seemed to indicate the issue was a P board, but that may have been from a newer unit. He also provided some helpful Powerpoint tutorials, which included steps to take once a new P board is installed. At this point, I plan to replace the P board and see where that leads me. If anyone has any other suggestions or requires a photo of the open unit, I'd be more than happy to oblige..
    • ruatha65
      • Nov 2014
      • 12
      I installed the P Board today and the TV is still dead. I'm going to try replacing the DG board, which is what the original troubleshooting flow chart told me was the issue.
      • ruatha65
        • Nov 2014
        • 12
        Latest update: I installed the DG board today. Panasonic makes access to the DG so much fun (sarcasm)! They stack another bracket and circuit board on top of it.
        After installation, I plugged the unit in and heard relays, for the first time since it died. Flipped it over and the on switch gave me a red LED (solid, no blinks of death). Used the remote and got an input display on the screen. Plugged cable box in, and got the best picture I've seen on it for years. That DG board must have been dying for some time.
        Keeping fingers crossed, and I'll be monitoring it to be sure no other issues crop up while in use for a few hours, but it looks good so far.
        Thanks Badcaps.net for all of the help. Specifically, the guides provided by Tom and TWC2005 were amazing and lead me to the fix. This is an awesome site that is now in my bookmarks. I was able to repair a plasma tv for about $160 (even including the P board I didn't need), so I saved at least $500-$600 on a new set. Not only that, but I enjoyed the challenge.
        Thanks again everyone. What a great community!
          Nice fix... I'm surprised you noted a picture quality difference - maybe the customer settings were different.... It can't otherwise effect the picture quality.
          • ruatha65
            • Nov 2014
            • 12
            Two possible reasons for the picture quality, neither of which have anything to do with real engineering or electronics:
            1. I was so excited that I actually fixed it that I saw more than what actually appeared on the screen.
            2. It has been dead for so long that ANY picture looked perfect.
            Oh, and the most likely reason is that I upgraded my cable service while the set was dead, so I had an HDMI capable cable box and used an HDMI cable for the first time on the TV.
            • tw2005
              • Oct 2011
              • 6458
              Or maybe you had a bad LVDS cable connection too?
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
              • k370
                Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                by k370
                I have a NM-A321 board that is dead, with no power at all.
                When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                • +3VALW
                • +5VAUX
                • 1.2VSUS_PWRGD
                • 3VALW_PGD
                • 1.05VAUX_PWRGD
                Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                09-23-2024, 11:57 AM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
