50" Plasma Vizio vertical lines across screen
  • caphair
    • Nov 2011
    • 1249
    Started happening a week ago and would usually go away if the set was turned off and back on. This is persisting now unchanged. Panel issue?
    Re: 50" Plasma Vizio vertical lines across screen
    Logic/panel control board or main board IMHO.
    Panel itself is OK...
    If control board has a self-test use that to diagnose which board is bad... otherwise it's hit and miss as to which is causing the fault.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Yup--I would say--Control-board too....
      TELEFIX
      • caphair
        • Nov 2011
        • 1249
        It ended up clearing up and has been working since. Should I still be concerned?
        • caphair
          • Nov 2011
          • 1249
          Are logic/control board and main board the same thing just different terms?
            It will probably go bad again, intermittent faults rarely fix themselves.
            • caphair
              • Nov 2011
              • 1249
              It's 99% of the time when the room is cold/tv hasn't been on in a few hours
              • mmartell
                • Oct 2013
                • 3189
                Two different things. Look under the main board usually.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • brad2157
                  Vizio E70-E3 Two white vertical lines
                  by brad2157
                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                  Replacement main board - Boots up fine, but starting...
                  12-13-2021, 05:11 PM
                • viking509
                  vizio e65 e3 LED tv color vertical lines center tv only
                  by viking509
                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                  03-21-2023, 12:48 AM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • afex
                  Samsung Plasma TV with vertical lines (model PN50B430P2D)
                  by afex
                  This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                  This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                  I have attached an image of the TV with these bars displaying....
                  11-08-2021, 09:23 PM
