Sony KDL37M3000 sparkly
  • CraigR
    • Dec 2013
    • 975
    Sony KDL37M3000 sparkly in picture. I have not run into this one before so not sure but I think the screen maybe bad or?? I have had to turn the brighness all the way up and also the backlight yet the picture still looks dark and too red and around some dark areas it's like blue or green sparkly. Ideas?
    Re: Sony KDL37M3000 sparkly
    Check gamma voltages on T-con board
    • CraigR
      • Dec 2013
      • 975
      OK, can you tell me where to tap off of for it? Or I see like 22 different little points that all say gama something.
      • CraigR
        • Dec 2013
        • 975
        Well I checked all those points marked Vgamma and readings as followed.
        1. 15.39v
        2. 15.26v
        3. 13.5v
        4. 12.31v
        5. 11.40v
        6. 10.81v
        7. 10.47v
        8. 10.16v
        9. 9.92v
        10. 7.52v
        11. 7.36v
        12. 13.21v
        13. 12.87v
        14. 9.23v
        15. 8.72
        16. 8.18v
        17. 7.46v
        18. 6.25v
        19. 5.67v
        20. 4.38v
        21. .707
        22. .301v
          Bad gamma chip, replace AS15 to fix.
          • CraigR
            • Dec 2013
            • 975
            or another TCON board right?
              Yes but often very expensive due to high failure rate.
              • CraigR
                • Dec 2013
                • 975
                Can't find the correct board or a repair kit. Even emailed SJ and nada.
                • Shinju
                  • Mar 2014
                  • 1239
                  I am pretty sure you can use any as-15 chip, atleast I remember reading it here or some other place.
                  • CraigR
                    • Dec 2013
                    • 975
                    anyplace you know of where I can buy just that chip?
                    • Shinju
                      • Mar 2014
                      • 1239
                      Can you not read the markings on the chip at all? Sometimes I have to take a digital macro photo and adjust the light via iPhone photo editor to read em.
                      • CraigR
                        • Dec 2013
                        • 975
                        As15-f
                        0718bg
                        b7322k64
                        • Shinju
                          • Mar 2014
                          • 1239
                          I have bought several as-15 chips from this seller and had a 100% success rate with their chips.
                          http://www.ebay.com/itm/100-NEW-IC-A...item35cc8fb341
                          • CraigR
                            • Dec 2013
                            • 975
                            ok, just ordered it. I will report back when it's in. Thanks!
                            • Shinju
                              • Mar 2014
                              • 1239
                              You bet!
                              • CraigR
                                • Dec 2013
                                • 975
                                Well got it in and that did the trick. Thanks!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Awesome!
                                  • CyberPhoenix
                                    Issue with picture quality of Sony bravia TV
                                    by CyberPhoenix
                                    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                    01-22-2024, 02:08 AM
                                  • noisykid
                                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                    by noisykid
                                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                    12-30-2024, 07:15 PM
                                  • iglitare
                                    by iglitare
                                    09-04-2025, 07:13 AM
                                  • tree5656
                                    diagnosing sony XBR-75X900H. NO PICTURE
                                    by tree5656
                                    This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                    11-09-2023, 04:55 PM
                                  • DKWS89
                                    Sony XBR 49x900E - Sound and backlight on but no picture
                                    by DKWS89
                                    Hey Guys,
                                    So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                    All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                    12-14-2023, 04:30 PM
