Panasonic TH-L32C30A Shut down 1 red blink
  • dkneyle
    • Dec 2013
    • 441
    It tries to start up. I can see the backlights appear to fire up at least twice. After about 10 seconds it shuts down with a single red light blink code.
    During the time that the backlights do come on the menu text does not look anywhere near as bright as I'd expect. I'm wondering if I have an inverter issue?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-L32C30A Shut down 1 red blink
    you'd have to check the manual but I suspect 1 blink is backlight SOS.
    My experience with LCDs is huge. I've done 1 ! panasonic , baby 19", turned out to be a bad cap and blown HFETs for me.
    • tw2005
      • Oct 2011
      • 6458
      Same model in NZ.
      https://www.badcaps.net/forum/showthread.php?t=41550
      having a quick read of that, what he has sounds like what I had with the 19" , continuous blinking and endless cycling of the TV trying to start the backlight.
      • tw2005
        • Oct 2011
        • 6458
        training guide should be similar setup. check the H Fets underside of the board for short
        • dkneyle
          • Dec 2013
          • 441
          Well the single red blink certainly means "SOS Backlight". I checked the resistance values of the inverter transformers and they check out OK. I'll look at those FETs. Otherwise it might be suggesting blown fluoro tubes do you think? I'll have another look tomorrow and let you know.
          • dkneyle
            • Dec 2013
            • 441
            Checked out those FETs and they seem to be OK. Certainly not short anyway. For anyone reading this thread, the type number of those FETs is TPC8116 (very hard to read). I've attached the datasheet which shows the pinouts.
            Those capacitors you mention are all Rubyicons in this set and physically look OK. I know what you said about yours looking OK, but I'll do a few more tests before pulling those caps out.
            The inverter transformers all seem OK from a DC measurement. Next I'll fire it up with a small 6W fluro tube across each of the 4 inverter outputs and see if we have high voltage being generated. If so I think I'll have to assume a backlight problem and start stripping down the panel.
            • tw2005
              • Oct 2011
              • 6458
              Yeah , with mine i suspect it was a rogue supply of caps they used. weirdest thing I've seen.
              Well looks like you have a decent fault to track but inverter cct and CCFL are not me.
              • dkneyle
                • Dec 2013
                • 441
                Looking through the back I can confirm that the CCFLs appear to be working. This TV has four HV outputs to drive the CCFLs. I disconnected each in turn to confirm that the CCFLs in that section of the panel went black. So I'm reasonably confident that the CCFLs are OK. (Disconnecting inverter outputs did not in anyway change the cycling on-off pattern.)
                The TV cycles three times before shutting down. The CCFLs come full on then drop back to about half intensity then shut off. As I say, this happens three times.
                Any thoughts anyone?
                • dkneyle
                  • Dec 2013
                  • 441
                  Measuring the secondaries of the inverter transformers shows that three coils read about 1270 ohms and the fourth reads about 100 ohms less (1170 ohms) open circuit. It doesn't change the behaviour of the set if I disconnect the output of that coil; it still cycles about three times before quitting.
                  (BTW, I did replace the two electros that TW2005 mentioned without any change of behaviour.)
                  • Ragga_NZ
                    • Oct 2014
                    • 4
                    • New Zealand
                    Did you manage to find out the cause, I have a similar problem with my TV same model.
                    • dkneyle
                      • Dec 2013
                      • 441
                      I'm pretty sure it's a crook inverter transformer. I can't source just the tranny so I think I'll have to change the whole board. I've just been waiting to sell a few old boards to justify the cost of the replacement for this TV
                      • dkneyle
                        • Dec 2013
                        • 441
                        Diagnosis was correct I believe. A failed (shorted-turn) inverter transformer. In the end I imported a fairly cheap second-hand power supply board via a private E-bay seller. All fires up perfectly now. I hope this helps others in the future. Couldn't source just the transformer.
                        • Vebririon
                          panasonic TX-P50V10E 6 blink led problem
                          by Vebririon
                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                          05-17-2025, 10:16 AM
                        • cloo
                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                          by cloo
                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                          After doing a factory reset this problem was gone and the picture was back to...
                          01-06-2025, 06:02 AM
                        • Chrissygizmo
                          Panasonic TX-48CX350B backlights but white screen , blank screen
                          by Chrissygizmo
                          Hi all, I’ve got a problem I hope someone can help me fixi.
                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                          01-11-2025, 03:18 PM
                        • SentraDude
                          (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                          by SentraDude
                          Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                          I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                          Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                          04-04-2023, 04:24 PM
                        • rmacintosh
                          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                          by rmacintosh
                          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                          The symptoms of the tv ar as follows:
                          • Plug AC in to back of TV
                          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                          • The 3 blink code is given by the power LED
                          • If the TV is unplugged and then
                          03-14-2020, 12:24 AM
