32 inch lcd sound no picture
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 32 inch lcd sound no picture
    Originally posted by gobby009
    so the problem with this tv is that from a cold start it would work for like an hour then loose picture but not sound with scart,tried svideo yesterday and the same.got sky hd plugged in today and its been going for 3 to 4 hours and hasnt lost picture yet.gonna leave it plugged into the sky hd all night and i will report back if it does loose picture.i plugged it into the sky hd to try and get a picture that reecey requested when it does loose picture but as i say its been going 3 to 4 hours on a hd connection with no loss of picture.
    Sounds like there is a motherboard fault probably cold solder joins under one of the chips.
    • gobby009
      • Oct 2014
      • 63
      Originally posted by budm
      So those Voltage readings on the inverter connector as shown when the backlights are not on?
      https://www.badcaps.net/forum/attach...2&d=1414623817
      no the backlights were on with those voltage readings,tv has been on around 6 hours now on hd connection with no loss of picture
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Bad mainboard then, you can get the for cheap on ebay.
        • gobby009
          • Oct 2014
          • 63
          so do you think the bad part of the board is where the scart and svideo connections are as they are down the side and the hd is on the underneath
          • gobby009
            • Oct 2014
            • 63
            tv was on all last night working fine on hd connection went to turn tv on this morning with hd connection lost picture after 3 minutes.backlights are on and so is audio.would it be worth putting some heat to the over the back of the mainboard with a heat gun.
            • gobby009
              • Oct 2014
              • 63
              #26
              update= grabbed a mainboard from ebay same board number just my board was a rev 6 this board i got of ebay is a rev 8 fitted the board tv works ok just the picture is a little dark.after examaning the board i got of ebay i noticed it has sum bulging caps on it and i think one cap is leaking.could this be the problem with dark picture?or is it because its a different rev number.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • slimmy182
                [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                by slimmy182
                Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                Looking on google I found this:...
                01-14-2023, 11:55 AM
