I'm getting a 7 blink code (SOS7) on my Panasonic TH-50PZ77U 50" Plasma (set is likely similar to the 42" TH-42PZ77U). The SOS7 code generally indicates a problem with the Y sustain circuit (i.e., the SC, SU and/or SD cards).
Here are the current symptoms.
If I run the set with the SC (Y sustain) and the SU (upper buffer) plugged in and the SD (lower buffer) unplugged, the set works with a picture on the top half of the screen.
If I plug in the SU and the SD cards without connecting the ribbon cables from the SD to the plasma panel, again the set works with half a picture.
If I plug one or more of the 5 ribbon cables between the SD and the panel, the set shuts down after a second or so with an SOS7 code.
When I power on with the SD card plugged in and cabled to the panel, sometimes the set tries to put up a picture (you can briefly see an off color image), but then the set goes to SOS7.
I tried two different SD cards and the set worked for about a week and then failed with the same symptoms. I don't see any obvious shorts on the SC/SD/SU cards.
When the SOS7 is triggered, the set goes into standby mode and more or less shuts down, so it's difficult to determine the underlying cause of the shutdown.
Does anyone have a suggestion on what might be causing the problem or what I could do to isolate the failed components? Could the problem be in another part of the set?
