Panisonic TH-42PZ800b six blink fault
  • Paniman
    • Oct 2014
    • 21
    Hi everyone
    Please can someone help I have a Panasonic TH-42PZ800B that was given to me as part of a house clearance. I was given to understand that the set had not been used for some time and was stored in a garage covered up
    The first thing I did was clean out the back of the set removing all dust where possible without removal of boards or cables.
    I then test the set with no AV inputs it worked! the set did not come with remote or brackets but did come with base,I then. Found some bracket and a genuine remote.
    The TV has been stored in my house waiting for brackets and remote.Yesterday I decided to remove the cheap Techwood and replace with my New to me Panasonic.
    I turned it on happy days until 20 mins later the picture turned negative but with mostly white. So I turn the set off and back on no picture but sound and no blink codes.
    I then left the set for 20 mins and it worked but only for 5 mins.
    So I removed the set and removed the back cover to check psu and connections all good . When I turn the set back on I only had half the screen (right hand side only) so I removed and reinstalled all ribbons on the buffer boards on y sustain (SU and SD) and x sustain ( SS) I also removed and refitted all ribbon cables and connectors to T-con (D) I also removed and reconnected the C1 and C2 data driver boards
    I then turned on the TV and the display worked but was black no snow I then removed the SC20 ribbon and reinstalled in my frustration I retired to bed with out further testing.
    This morning I got up and turned on the set and it worked for 30 mins so thinking I may have fixed it I connected up to the sat and DVD it worked for a further 2 hours with no problem but wait for it! the negative white image came back for 30 sec and then the picture was good again for a further 20 mins then whilst have lunch with the family in the other room a loud crack was heard I come into the lounge and the TV was off with the six blink showing on the led
    Manual says driver SOS1 (SC energy recovery circuit) SU SD and SC
    A very knowledgable chap in the UK suggest this forum for help his opinion was that the loose sc20 connection may have caused a bad waveform to take out the SC board but this fault is very very rare!
    Sorry for the long story but thought it best to give the full story from start to finish
    Many thanks
    Regards
    Paniman
    Re: Panisonic TH-42PZ800b six blink fault
    That was probably me, from Sordids on eBay right...? That's not me, but some advice I passed on to him.
    A loud pop and 6 blinks can really only indicate an SC board fault. Usually, the SU/SD survive but there is a way to be sure. 6 blinks is pretty rare but we have seen it on other Pannys (7 blinks is most common and that can definitely be risky to the buffer boards.)
    Now since the picture was going bad, there is a possibility that the D board (T-con equivalent) was causing this. It is also possible it is a coincidence, or if the SC20 cable was not seated properly or it came loose, this could happen too.
    Pictures of parts inside the set would go a long way to helping us diagnose it.
    • Paniman
      • Oct 2014
      • 21
      Hi
      Yes it is me from eBay
      Many thanks for yet more info.
      I rechecked the connections as you said all good. Do you want detailed photos of all the boards and areas if so I will come with these tomorrow and post here
      Many thanks
      Regards
      A
      Paniman
        Pictures of all the boards would be useful, and one of the whole set. The PZ800B is related to the PZ80B but has a different layout, I believe. The parts are usually interchangeable, except for the main board which has 4 HDMI port support (3 HDMI rear & one HDMI on the front.)
        Can you confirm one thing - on the SC and SS board there should be some small LED lights, do these light up at all now once plugged in?
        • Paniman
          • Oct 2014
          • 21
          Hi tom
          Here is some photos
          Just to let you know the green LEDs on on the sc and SS boards are lit until the auto shut down followed by the six blink on the front
          Regards
          Paniman
          • Paniman
            • Oct 2014
            • 21
            SC board
            • Paniman
              • Oct 2014
              • 21
              Power supply
              • Paniman
                • Oct 2014
                • 21
                SS board
                • Paniman
                  • Oct 2014
                  • 21
                  D or t-con board
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Well, We Sure cant find any faults visually--With THOSE photos!!
                    Any chance of some Clear ones of the SC and SD....?
                    TELEFIX
                      As Alastair says it's hard to see much detail in those photos.
                      Remember we don't have the luxury of seeing what you can see, and we don't have the chassis in front of us. So clearer photos are necessary.
                      • Paniman
                        • Oct 2014
                        • 21
                        Hi Alastair and Tom
                        Yes I know the photos are poor, I have taken some better ones but my p.c has died so I am unable to upload from DSLR. Unless it's the iPad camera (Hence the poor photos)
                        I will get some photos posted via a photo bucket link once I have sorted the PC (tomorrow hopefully)
                        What I can say is they are no obvious faults that I can see ie swollen caps or burning on the boards (of cause we all know that a non swollen cap does not mean there good) dame these electrolytic caps!!!
                        But the boards have the same numbers that Tom has for sale at the moment ie SD,SC,SU and SS
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          With a Panasonic, its VERY Unlikely to be Caps anyway!
                          More likely dead IGBT's, MOSFETS, Chips, Thermal-Fuses, or surface-mount multi-layers.....
                          --Basically everything BUT an electrolytic capacitor....
                          TELEFIX
                          • sordids999
                            • May 2013
                            • 2161
                            No its me who has them for sale
                            but I want to be sure you need my parts before u buy them due to myself having a few returns for wrong diagnose
                            • Paniman
                              • Oct 2014
                              • 21
                              Thanks Alastair glad you put my mind at rest re the caps!
                              Sordids999 sorry to get confused with tom
                              Photos will be uploaded tomorrow
                              • Paniman
                                • Oct 2014
                                • 21
                                Hi Guys
                                Heres the photos I promised
                                http://i1302.photobucket.com/albums/...psdddfda7c.jpg
                                http://i1302.photobucket.com/albums/...ps30d77d38.jpg
                                http://i1302.photobucket.com/albums/...ps724ad96c.jpg
                                http://i1302.photobucket.com/albums/...ps89b639fb.jpg
                                http://i1302.photobucket.com/albums/...ps8b3402a8.jpg
                                http://i1302.photobucket.com/albums/...ps2b618310.jpg
                                http://i1302.photobucket.com/albums/...ps8b4eddca.jpg
                                http://i1302.photobucket.com/albums/...psd0bb2bb1.jpg
                                http://i1302.photobucket.com/albums/...psbad619bb.jpg
                                http://i1302.photobucket.com/albums/...ps7a847aaa.jpg
                                http://i1302.photobucket.com/albums/...ps67d85d61.jpg
                                • sordids999
                                  • May 2013
                                  • 2161
                                  updated pictures
                                  • Paniman
                                    • Oct 2014
                                    • 21
                                    Hi guys
                                    What do you think I should do next?
                                    Many thanks
                                    Paniman
                                      I think it would be a good idea to remove this part:
                                      https://www.badcaps.net/forum/attach...5&d=1414610956
                                      And check for damage, burn marks, etc.
                                      If there are none obvious a multimeter will have to be used to find short circuits.
                                      • Paniman
                                        • Oct 2014
                                        • 21
                                        Hi tom
                                        Have removed the board and will check it out this evening after family time
                                        Is it possible that the loud pop herd just before the 6 blink code could be a fuse on the powersupply (P) board that would have been taken out by the fault on the SC board?
                                        Will report back later.
                                        Paniman
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                          ESR meter came to the rescue again today with a PLC I/O card fault
                                          by sam_sam_sam
                                          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                          12-18-2023, 08:17 PM
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
