Panasonic TH-42PZ85E --> Completely dead!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    #161
    Re: Panasonic TH-42PZ85E --> Completely dead!
    Will check that tomorrow, dont have time right now. Ps post costs is not a problem.
      Found my PSU. It's definitely not usable as-is, missing lots of parts, but MC701 is untouched.
      I had it wrong, this one is one someone before me butchered completely doing the MC201/MC301 repair. I tried, but ultimately failed to repair the damage they had done.
      • inmoco
        • Nov 2014
        • dover
        #163
        Hi Tom i have exactly the same problem as this (no power what so ever) but am not getting 5v at Cathode of D551 on P. Any ideas?
        Sam
          Sam
          In which case you have a different issue. Best to start a new thread and post clear photos of the power board.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            #165
            Hi Tom , forgot to update this thread! Shame on me , now i cant help other people with this thread.
            Got a new PS and the tv turned on. The problem was the CPU on the powersupply.
            My girl accedently damaged the screen while cleaning it , it now was a small crack on the screen. The coating layer is damaged and unfortunately this panel does not have a glass front like earlier plasma's.
            Will use this tv as a test machine.
            So whoever has the same problem , a new PS did it for me.
              These panels -do- have a front protective glass. However the glass has an antireflective coating and so cannot be replaced with conventional glass.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #167
                True , i mean a glass cover that you can remove from the panel
                • rads26g
                  • Aug 2016
                  • poland
                  #168
                  hello, what do mean CPU on power supplay, you talking about mc701 module.
                  • max-power
                    Dell E6540 laptop completely dead after dssasembly
                    by max-power
                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                    03-24-2025, 08:49 AM
                  • wangbreeze
                    T480s random shutoff and then completely dead
                    by wangbreeze
                    Hello Gurus,
                    I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                    I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                    Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                    charger gave - 20V - ok
                    U101B
                    02-03-2024, 04:57 PM
                  • pavski
                    Completely dead MSI z490 tomahawk
                    by pavski
                    Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                    I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                    t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                    Can you please let me know if this is indeed incorrect and what else should I look at next?
                    Thanks!
                    06-02-2024, 02:42 PM
                    HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) Specification for Upgrade or Repair
                    This specification for the HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Casio G-SHOCK boardview and 1030 G4 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 11:39 AM
                    HP ProBook 450 G6 + Casio G-SHOCK Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G6 + Casio G-SHOCK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Casio G-SHOCK boardview and 450 G6 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 09:53 AM
