un55d6000sf
  • chenny
    • Oct 2014
    • 9
    un55d6000sf
    My 55" Samsung LED TV stopped working. The screen does not power on. There is no sound. The indication light blinks in twos.
    I would appreciate any help in diagnosing the issue -- what to do, what tools I need, etc.
    Thanks very much in advance.
    Best,
    Chris
    model code: un55d6000sfxza
    version no. H302
    35.5 months old.
  • tw2005
    • Oct 2011
    • 6458
    Re: un55d6000sf
    35.5 months old, (LOL)
    I think if you do a search on UN55D6000 there's a few threads with issues, backlighting seems to be one, mainboards another.
    I have a D7000 with multi channeled LEDs and one is open causing localised loss of lighting and endless reboot. not what you described but have a search and read what's already out there.
    • Shinju
      • Mar 2014
      • 1239
      Re: un55d6000sf
      I think with the LED panels you can pull the mainboard to ps cable, plug the set in and the LEDs should illuminate. I have only had a few LED panels and they all turned on so I weeded out the ps as the issue.
      I know this works for the ccfl Sammys.
      • mmartell
        • Oct 2013
        • 3189
        Re: un55d6000sf
        Yes with this model you can force backlight on by removing the mainboard to power subbly ribbon cable and powering up. Report back.
        • chenny
          • Oct 2014
          • 9
          Re: un55d6000sf
          Thanks for the responses. I am going to devote a few hours to this tomorrow. Just so I am clear, I am going to disconnect the cable going from the Main Board to the PS.
          By PS do you mean the board referred to in the attached documents as the SMPS Board (or IP Board)?
          Thanks.
          I found the attached documents, which are for similar model(s).
          Thanks!
          • mmartell
            • Oct 2013
            • 3189
            Re: un55d6000sf
            PS = SMPS = Power Supply
            • mmartell
              • Oct 2013
              • 3189
              Re: un55d6000sf
              And those docs are not helpful for the D6000, at least where the backlight is concerned. Just remove the cable and power it up.
              • chenny
                • Oct 2014
                • 9
                Re: un55d6000sf
                Two more facts to help diagnose:
                When I got back home last night I plugged in the TV, and the screen went on for about a minute or two before shutting down again. This was the first time I tried plugging it in after it was unplugged for more than hour. Perhaps something reset?
                Regardless, it stopped working. I tried this again this morning, but did not get the same reaction.
                I just unplugged the ribbon cable connecting the PS and the other board. I unplugged it from the mainboard connector.
                When I plugged it back in, I did not see any LEDs illuminate. The indicator light did not even go on.
                Here are pics of the back.
                Thanks!
                • chenny
                  • Oct 2014
                  • 9
                  Re: un55d6000sf
                  On page 3 of the manual found at the following link, it says that a jumper cable must be inserted into the cable ends to activate the back light. That manual is for a different model. Not sure if that is relevant.
                  Thanks.
                  • chenny
                    • Oct 2014
                    • 9
                    Re: un55d6000sf
                    So as I read more through this site, it appears the issue is probably the PS because (i) the LEDs did not illuminate when I disconnected the cable between the PS and mainboard and powered on; and (ii) the screen actually came on last night, albeit briefly.
                    Does that sound about right?
                    I was going to order the board (bn44-00424a) from newegg, which has it in stock. Shopjimmy is out of stock.
                    If that sounds right, do I need any tools (besides a screwdriver) to remove old and install new PS?
                    Thanks very much for help with this.
                      Re: un55d6000sf
                      In my opinion given the number of LED array failures on this, it's more likely an intermittent or bad LED in the panel. This is repairable but is a right pain in the ass to do as the panel will have to come apart completely.
                      • chenny
                        • Oct 2014
                        • 9
                        Re: un55d6000sf
                        That would definitely be above my pay grade. Even if that is more likely, seems worthwhile to order PS to see if that fixes problem. No?
                        Thanks.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Re: un55d6000sf
                          I would order the power supply , if it does not fix the problem you can always sell or maybe even return the power supply.
                          I would try that first!
                          You don't need any other tools , maybe a anti static wrist band but just be careful. Its like a pc , plug and play
                          If you are lucky the cable's/boards have numbers on it and its easy to see which cable goes where!
                          • chenny
                            • Oct 2014
                            • 9
                            Re: un55d6000sf
                            I ordered the PS. I'll report back after I install.
                            Thanks for the comments -- they are greatly appreciated.
                            • chenny
                              • Oct 2014
                              • 9
                              Re: un55d6000sf
                              I installed the new PS, but, unfortunately still no video.
                              I need to find a decent repairman. I assume Geek Squad is out of the question.
                              Anyone in NY area have any recommendations?
                              Thanks.
                              • jagiro84
                                Alienware x15 R2 no memory detected (hell repair job, 6 months later)
                                by jagiro84
                                Hi guys,
                                its been around 5-6months since i left this board on side to rest my brain cells and now came back to try and repair it again.
                                The laptop in question has issue where it gives error code on power on which is 2red and 3 blue
                                In short, by Dell specs this means "Memory not detected: "
                                Now one important thing the laptop would turn on fine when i leave it in the refrigerator for 5-10min and i could work\play games with it for days and months as long as i dont turn it off
                                but after a while this trick stopped working as wel
                                12-29-2024, 05:05 AM
                              • Hairspring
                                Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
                                by Hairspring
                                In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
                                Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
                                Anyhow,...
                                12-04-2022, 11:18 AM
                              • davidebaldini
                                UPS ruins batteries every three months
                                by davidebaldini
                                Problem description:
                                My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                                UPS model:
                                The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                                10-02-2019, 06:19 AM
                              • Ruptor
                                Hitachi 55" TV dead after 18 months (Vestel 17MB100)
                                by Ruptor
                                I couldn't find any other thread that matches my TV problem but have been told it is a common fault. The fault is a flashing LED as if it is in upgrade mode that happens after a few seconds and stays forever. I can't remember all the tricks that have been tried like holding the select button when powering on but nothing worked. The shop sent me a flash drive to plug in a USB port but that did nothing either and they said it was dead which is disgusting for a piece of solid state electronics. I took the back off eventually after removing 34 screws to check for blown caps but everything looks new...
                                09-27-2021, 10:19 AM
                              • wrobbie
                                Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
                                by wrobbie
                                My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
                                02-26-2025, 10:02 PM
