Panasonic TX-L42B6B issue with image
+ More Options
Posts
  • danjcarr1
    • Jul 2012
    • 35
    • Uk
    Hi all I have just picked up a 42 inch Panasonic LED Tv that has a fault with the image.
    When turned on the tv is fine and displays normal.
    After roughly 10 minutes the image gets a green tinge to it.
    Could this be a bad t-con board?
    Any input would be appreciated.
    Dan
  • danjcarr1
    • Jul 2012
    • 35
    • Uk
    Re: Panasonic TX-L42B6B issue with image
    • danjcarr1
      • Jul 2012
      • 35
      • Uk
      image ru
      • danjcarr1
        • Jul 2012
        • 35
        • Uk
        image post
        • Shinju
          • Mar 2014
          • 1239
          Looks like a Gamma failure to me! Pop the back off and snap a photo of the t-con board.
            More likely it's a loose LVDS cable or bad main A/V.
            Too new for common gamma chip fault (AS15 etc)
            • danjcarr1
              • Jul 2012
              • 35
              • Uk
              upload an image
              • danjcarr1
                • Jul 2012
                • 35
                • Uk
                I'm leaning towards a bad main board as it comes on fine and then after a few minutes the fault appears
                  Fiddle with the LVDS cable (between main board and T-con board) and note if the effect comes and goes.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Or, when the panel is cold, with the back off heat up the MB or LVDS cable with a hairdryer and once its warm turn it on and see if that failure happens right away.
                    • danjcarr1
                      • Jul 2012
                      • 35
                      • Uk
                      I have had the back of the TV and can confirm that pressing on the LVDS cable towards the T-con board connector causes the fault to appear/disappear so it looks to be a bad connection on the LVDS cable.
                      Thanks so much for the help Tom and Shinju
                      • remmurdmd
                        Vizio E65-E1 strange image issue
                        by remmurdmd
                        Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                        10-02-2022, 09:12 PM
                      • Ancient1
                        Strange LG TV issue : Image vertical lines in black screen
                        by Ancient1
                        Hi
                        Asking for a friend.
                        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                        but here its the opposite !
                        TV has new T-con = same issue
                        A missing panel voltage would have global effect
                        So , what should one do ? how can I find where the fault is ?
                        Thanks !...
                        02-05-2025, 03:37 PM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • thslr2020
                        [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
                        by thslr2020
                        Hello.
                        I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
                        1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
                        2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
                        3. Disabled Intel ME, Hyper-V & Vt-d
                        4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
                        5. Try from fresh Win 8.1(boot with USB)
                        Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but...
                        06-14-2023, 12:09 AM
                      • Andre Gilbert
                        by Andre Gilbert
                        11-20-2024, 08:52 PM
