lg 47le7900 main board
  • thuss
    • Jul 2012
    • 321
    • uk
    Hi
    My tv comes on the menu displays etc . But when I connect the hdmi cable or the scart the tv display states no signal.
    When I do connect the scart from the dvd player I get sound but no picture(but I do get the lg logos stating no signal).
    Has anyone come across this problem before, before I change the main board I was hoping to fix the main board?
    thanks in advance
  • thuss
    • Jul 2012
    • 321
    • uk
    Re: lg 47le7900 main board
    working I just reflowed the main chip
    • nomoresonys
      • 12331
      • U.S.
      have a jvc doing same thing, which main chip, where was it located?, wondering if my problem is the same, glad you sorted it out, thanks.
      • thuss
        • Jul 2012
        • 321
        • uk
        its on the main board, I simply followed the prints from all the hdmis usbs etc and they all went into a main chip. hope that helps
        • Azim69
          • Nov 2016
          Hey Guys.
          Can you please give me instruction step by step how to do it?
          Thank you in advance.
          • diif
            • Feb 2014
            • 6978
            • England
            Originally posted by Azim69
            Hey Guys.
            You are aiming to heat the solder balls that connect the chip to the board in a controlled manner up to around 230c to get them to melt and remake any broken connections. There are many videos on YouTube to give you an idea of the different ways to achieve this, from shop a bought BGA rework station to home made stuff and there is at least one member that uses a gas stove to reflow.
            I spent many hours with a friend setting up my station, then many more hours practising on scrap boards. It is not a job I would do with no experience.
            What's your skill set and what tools do you have ?
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
