SAMSUNG LCD LN40D610M4FXZA - Backlight & Sound OK. No pitcure - Blank Screen.
  • raami_81
    • Oct 2014
    • 4
    I have a 3 year old SAMSUNG 40" LCD TV (LN40D610M4FXZA).
    Last week, observed 75% of screen with horizontal while lines and 25% with good picture. I thought that cleaning the LVDS cable edge would solve the problem.
    After Cleaning the LVDS cable, There is no picture at all. I see back light is on, SOUND is OK. Can play video files using USB source(no video just the sound is audible).
    I thought of seeking a technician and called SEARS home services, technician over the phone suggested me that 100% is chance of BAD PANEL and not worth fixing it. I asked him to visit and diagnose the problem. He diagnosed and told that it is possible T-CON board. He ordered OEM T-CON board ($87) and couple of days later when he replaced the T-CON Board, the problem is still out there. He told me that it is a BAD PANEL and refunded the amount for T-CON board.
    I still believe the TV can be restored to its working state.
    Please suggest and share your expertise to troubleshoot the problem.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: SAMSUNG LCD LN40D610M4FXZA - Backlight & Sound OK. No pitcure - Blank Screen.
    From what I've read so far any screen with Horizontal lines is the effect of a bad panel.
    So i think the SEARS Tech was right. IMHO the only fix is to replace the panel, though.
    • Shinju
      • Mar 2014
      • 1239
      I am also with the Tech too, these Samsung panels suffer failure A LOT. You could try a new mainboard but I think you are going to be wasting time and money.
      • Shinju
        • Mar 2014
        • 1239
        One other thing you can try is disconnecting one side of the T-con power on the TV and see if half a picture comes up. Rinse and repeat for the other side.
        • raami_81
          • Oct 2014
          • 4
          Thanks Everyone for responding to post.
          Yeah, It's true, Total waste of time and money. But Still I do not want to trash it hoping that there might be a solution to this.
          I have replaced the LVDS cable and I can see the picture now (75% with horizontal lines and remaining 25% with good picture). Please see attached image.
          When we replaced a T-CON with Sears TECH, we were not able to verify the pitcure as LVDS was faulty that time. Now I am going to order a new T-CON and see if this resolves it.
          I will also try shuffling T-con cables. Thanks for all your suggestions.
          Please post your comments after looking at this image, anticipating to hear that it is not the panel and something else.
          Also, before deciding to buy a new one, one last try as instructed from this site.
          http://www.highdefforum.com/flat-pan...ln-t4661f.html
          • ehboy
            • Sep 2014
            • 66
            Can't quite understand what shuffling the cables will accomplish. More likely to be damaged by manual twisting and bending than just sitting there. If they are already faulty, shuffling them will make no difference.
            Best wishes.
            • raami_81
              • Oct 2014
              • 4
              Ok. I got a new T-CON board, and display is still worse. As Shinju suggested, I tried disconnecting Right side of T-CON leaving Left side intact with panel.
              Half screen display was perfectly fine, when disconnecting left side of T-CON and connection RIGHT side to Panel, There is no image All I got is only vertical lines and display fades off.
              I tried tapping the TABS and noticed nothing. I suspect that right side panel LCD driver board is at fault and wondering if there is any remedy to it.
              Please take a look at the pictures and suggest
              • mrtek
                Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                by mrtek
                Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                11-26-2024, 09:58 AM
              • mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                by mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                11-25-2024, 05:22 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • mar1in
                Samsung TU8000, backlight and sound on, stuck in blue screen
                by mar1in
                I've got this Samsung here that would be stuck in a boot loop.
                After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                Thanks in advance
                11-08-2023, 05:43 PM
