Using Peak ESR60 Meter
+ More Options
Posts
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Have a friends set JMB set that takes ages to start up, I removed PSU and obvious bulging caps, so thought I would try my new ESR meter with the caps in circuit
    Most are OK but a few I "in-circuit/leaky" so removed them and tested out of circuit and they are OK, so can someone help explain this? or shall i just replace any that say "in circuit/leaky" when tested on the PCB? One for example is a 200uf 16v, in circuit I get the "in circuit/leaky" ESR reading of 0.30ohms. out of circuit it is 223.4uf and ESR 0.28ohms.
    Help
    Re: Using Peak ESR60 Meter
    Well, there's no specific rule, but I would say 0.28 ohm is bad for a 220uF capacitor.
    My general rules are something like this:
    <10uF 1 ohm ~ 10 ohm
    10uF~100uF 0.1 ohm ~ 1 ohm
    100uF~470uF 0.05 ohm ~ 0.1 ohm
    >470uF <0.05 ohm
    Capacitors can only be reliably tested out of circuit, despite what manufacturers claim.
