Has anyone used this before Signstek MESR-100 V2 Auto Ranging in Circuit ESR LCR Meter Capacitor
    • Jul 2011
    • 6070
    I wanting to know if anyone has used this capacitor tester and what they think about it and weather or not it is worth the money or not
  • chth96
    by chth96
    03-09-2024, 10:03 PM
  • shouri
    Dell latitude e5490 auto restart
    by shouri
    Hi guys, can someone help me?
    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
    Board model is dm70 la-f401p rev:1.0 2017-09-20.
    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
    After a few days test, is seems ok.
    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
    12-10-2024, 09:27 PM
    12-31-2023, 06:04 AM
  • jorpec
    by jorpec
    Hi
    Thnaks
    01-23-2023, 10:37 AM
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
