Panasonic TH-42PZ8BA completely dead (no standby LED), 5VSTBY present)
    Got another PZ80...actually two. This PZ8BA for £35 on eBay I'm working on now, and a 10 blink PZ85 (which is already fixed, common fault) for £50. Nice to score two at once...
    This one is different to my previous PZ80 which had same symptom: that one had no 5VSTBY, due to AC DET fault on PSU. This one does have 5VSTBY so it points to A board.
    Going to look into the A board now...
    Re: Panasonic TH-42PZ8BA completely dead (no standby LED), 5VSTBY present)
    Hmm, STB3.3V is dead (47mV), STB5V is present on A board...
    15kohm to ground so not shorted. Generated on A board.
    I am thinking IC2403 (C1AB00002877) is bad, as that appears to be STB3.3V source... hope I can source it. Looks easy enough to replace.
    • tw2005
      • Oct 2011
      • 6458
      What do you think about injecting 3.3v there externally?
        Gonna try that tonight.
        I've also got the PZ85 I can pull A board out of and see what that does, it's not 100% compatible but ought to get panel to show something...
        • tw2005
          • Oct 2011
          • 6458
          It'll be interesting to follow and learn
            Tried feeding in 3.3V, no joy, board just sucked up 700mA and no power light, so guessing that the ASIC does a few other things too and it's bad.
            Will try swapping A boards over soon.
              Bingo, unplugged A board completely, click-click, primed screen followed by white. Panel looks good, as expected no burn in. Will try swapping A boards next.
                Swapped A boards over and it fired into life with a perfect picture.
                So need to fix this A board, hmm...
                  If anyone knows of or has a good source of 68874Y03 please let me know (IC2403)
                  Can find one from Italy for £12 but that will take over a month given how Italian post works.
                  • tw2005
                    • Oct 2011
                    • 6458
                    So resistance to gnd on the ASIC for the 3.3, did they match with the working board and the dead?
                      Good board 14.3kohm, bad board 15kohm, no significant difference.
                      • tw2005
                        • Oct 2011
                        • 6458
                        could send an enquiry to CHS, who's the major panasonic repairer in the UK?
                        Send GTV Watford a message through EBay, although I think he's heavy handed with $. I've done that but contacted local panasonic parts distributor and local ended up cheaper.
                        is'nt one of our members in the UK a panasonic repairer?
                        • tw2005
                          • Oct 2011
                          • 6458
                          So I wonder, how does a 15k load pull 0.7A on 3.3V? Or am I am looking at this too simplistically?
                            Can be a parasitic diode, if it's hiding behind a diode drop for example, inside the IC. Damaged semiconductor structures can do anything. They can be completely non obvious when parasitic SCR structures or broken transistors get turned on. There's probably 50 or 100 transistors just involved in the regulator portion of that IC.
                            Will shoot off some messages to the other guys - can also buy the part from USA for $6 plus ??? shipping, so maybe I'll try that. C1AB00002877.
                              Found a Polish supplier, but I think they only ship to Poland, no country selection.
                              EncompassParts various sites want minimum $200 order, ugh.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Yeah, I have the same issue. No O'S shipping or they want a huge$
                                I have uses freight forwarders once for an Ic , blew the cost right out. Ok if the purchase for a number of goods.
                                All we need really is for someone to volunteer to order it and then forward it
                                PM sent
                                  Managed to get another chip, from an incompatible board... (TH-42PZ800B) which I promptly swapped over.
                                  STILL DEAD! 3.3V is dead. Checked soldering... all looks good (did it again to be sure)
                                  Then I noticed burn damage around one of the HDMI ports. I figure this is power surge damage. I've found a pricey board on eBay (£45) but have ordered it... it's got an additional VGA port but I should be able to make it work.
                                  I figure this TV has been a victim of a power surge through HDMI, maybe the Analog Devices HDMI part is damaged, and that has an active short - perhaps loading the 3.3V down too much. Even if I could get this set working, there's almost no chance the HDMI port(s) would work. Hence why I need a new board.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    Perhaps the burnt protection components are causing a short. At least remove them, clean the area and see what happens?
                                    -David VanHorn
                                      Not shown in the photo, but the HDMI IC also has a burn hole in it... and they are only termination capacitors/resistors not protection components unfortunately.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        nasty, lightning comes to mind
                                        • eukal
                                          Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                          by eukal
                                          Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                          I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                          I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                          I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                          07-01-2023, 01:00 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • rex98
                                          JS47A/JS57A/JS77A NM-E531 onboard ram disable
                                          by rex98
                                          hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
                                          nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
                                          maybe you could help me how to shift these resistors to disable its onboard ram.
                                          this is is the presents and not presents...
                                          Today, 03:39 AM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • Nirrain
                                          Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
                                          by Nirrain
                                          I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
                                          I've tried to change VSUS to high but it made the issue even worse so changed it back.
                                          However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
                                          When turned on the green LED flashes 6 times and then stays on continously....
                                          07-09-2021, 02:38 AM
