Panasonic TC-P50C2 No Power
Re: Panasonic TC-P50C2 No Power
I was thinking that too. I got the TV yesterday and was told it went out the night before. I should check the weather from 2 days ago. Assuming that it really happened then. You never really know. I'll just part this out now. I'm not going to spend $150 on an A board. And I don't have the poles for the base.------------signature starts here------------
Pretty good really, should be enough heat cycles to test the repair. Just think of all the boards that probably got thrown out. i'd love to have a go at hot air, BGA looks very precise work though.
thanks for the feedback, it's always an education
cheersComment
Plan on having a reflow oven if you intend to replace them yourself.------------signature starts here------------
http://www.instructables.com/id/BGA-rework/#step1Comment
Or at least try on a cheap board. Not on one which is about $160 used.------------signature starts here------------
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
