LG 42V7 Random Sparkles
  • Engineersfoot
    • Feb 2014
    • 24
    • Mexico
    I posted about this TV a while back and I discovered the original problem was a bad main board. After replacing it the tv started working great until it started giving me a new problem.
    After around 30 minutes of use I get sparkles all over the TV screen after changing from a bright picture to a dark one. When the on screen display messages dissappear they leave a patch of sparkles where they where. From what I've read this is a classic problem with these LG plasmas.
    The thing about this one is that the fault does not occurr when the back cover is off, ie it's heat related. When the fault is occurring the status LEDs on the TV change from 3 lit LEDs to only one. I can recreate the fault by blowing hot air down to the control board. Because of this I don't think the issue may be due to the y sustain but rather due to the control board. The training manual calls these LEDs "status" LEDs but it doesn't specify at all what they actually mean. Anyone on here know?
    All voltages are dead on where they should be.
    My question is, would a bad Y sustain board cause the status LEDs to change or are the status LEDs on the board only related to the control board itself? You guys think I should just wint it and change the control board? I don't want to risk changing a board only for it to turn out i got the wrong thing.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 42V7 Random Sparkles
    The set needs a Control-Board Firmware Update. Capkid in US can do it, as he's closest to you and so can I, but I'm in UK......
    TELEFIX
    • Engineersfoot
      • Feb 2014
      • 24
      • Mexico
      Hmm that kind of sucks.
      Is there any way of updating the firmware without the use of the LG jig? Anything else I might be able to do?
      How does the firmware affect the operation of this board and why does the fault end up being heat related? Would there be a way of solving this problem simply by supplying additional cooling?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Well--as a temporary fix you can try removing the heat-pad from the temp sensor and the bracket covering it on the corner of the control board. The 'status' LED's are temp indication.
        Mal discharge is a known issue with LG sets, the timing/width of the negative spike on the positive ramp is extended to improve panel reset/cell discharge, prior to re-address...
        (At least that's what appears the difference of before and after update that Ive noted)
        A careful adjustment of SET_Up and SET_Dn can help, as well as replacing all the poxy surface-mount 33uF and 68uF caps on Y-SUS (Use 47uF and 100uF as replacements)--but ultimately only F/W update will cure it properly.
        TELEFIX
        • capkid
          • Oct 2010
          • 1339
          I got your PM. As I mentioned, I haven't successfully flashed a 42V7 board. I know that others have had issues with that revision, also.
          LG Plasma Mal-Discharge Correction Service
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            One and only V7 Ive done did improve--but not completely cure the sparkles. I think that the V7 series is just so old now with many thousands of hours on 'em its luck of the draw. These early LG panels don't seem to last well IMO...
            I certainly wouldn't waste any money on expensive parts etc for it!
            Even when working well--They haven't got what could be called--A Brilliant Picture--being a 480 EDTV panel, although I did have a low hours Sony (Full of Nichicon Caps instead of the usual crap-cap that LG use) That version wasn't a bad picture--Except for its screen-burn....
            Advice to O/P, 'Frig' the temp sensor so it works when hot and flog it fast Haha!
            TELEFIX
            • Engineersfoot
              • Feb 2014
              • 24
              • Mexico
              Hmm Okay, I'll give the temp sensor thing a try. I actually tried changing the thermal pad on that thinking it was a voltage regulator that was overheating. I guess the only voltage regulators are the fets.
              The TV has sparkles from cold but they're not noticeable once you step a couple feet away, from what I read that can be considered normal.
              • Engineersfoot
                • Feb 2014
                • 24
                • Mexico
                Alright, tried removing the pads on the temp sensor. Still does it anyway. Temperature LEDs change. Is this sparkle problem normally related to the LEDs and temperature? I haven't seen too many people mention that along with the sparklng issue.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Normally it gets better as the set warms up--not worse, as the gas-pressure in the panel increases, ionisation becomes harder to achieve--due to the higher pressure.
                  --Thats why there's temp monitoring on the control-board to compensate.
                  For some reason--the panel becomes more sensitive as it ages, becoming more easy to ionise the gas, thus causing the issue.
                  Did you try the SET_Up/SET_Dn adjustments?--These can have drastic effects on the mal-discharge.
                  TELEFIX
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Did you try altering the small things on the mainboard/ysus/xsus? Sorry , don't know the name but this link shows what i mean! ( Im dutch :p )
                    youtube.com/watch?v=CkxpNpJZFyM
                    • Engineersfoot
                      • Feb 2014
                      • 24
                      • Mexico
                      Hey, I haven't tried the Set Up/DN adjustments. Is that the one where you need to watch the wave form? If so I don't have an oscilliscope but perhaps I can get away with tweaking around and marking the original positions.
                      Any rough guides as to what I should do? Turn stuff up down or is it an experimentation thing?
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        The power supply is new right? Or is it 2nd hand?
                        I had the same problem with a LG plasma , it was really viscible in light colors like white/yellow.
                        I started to alternate first on the board on the leftside of the TV. You have to change the values clockwise ( slowly to the right ).
                        Your sending more voltage to those boards so be carefully and see if something is changing or not.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          No! Shouldn't Randomly Adjust PSU board without monitoring the voltages--doing so, could end up in disaster by blowing summit up! (Been there, Done that Many times in the last 40 years!)
                          Check voltages by all means and set Properly with DVM/DMM
                          The SET_Up/Dn adjustments Should be done with a Scope--but when correct--with a scope--will still give the Mal-Discharge issue.
                          Careful alteration of first SET_Dn then SET_Up should help the issue, and Maybe then Reducing the Vs Voltage by 5V or so can help in some cases,--For this, you'll need a DVM/DMM The Correct Vs voltage is marked on the panel sticker somewhere around 180-200v.
                          Mark the pots with a pencil first to re-set to same spot if the adjustment fails to help.
                          --Dont twiddle anything else--as it wont help and can make for more problems!
                          TELEFIX
                          • Engineersfoot
                            • Feb 2014
                            • 24
                            • Mexico
                            Alright got it. Yeah I have a DMM and everything, I work on electronics just not plasmas and right now I don't have my oscilliscope. Power supply is original. Nothing wrong there. We'll see what happens.
                            • semiRocket
                              • 22
                              • Croatia
                              Just to be sure, is attached picture the case of what it's being talked about in this thread?
                              I have a LG 42PC3RA, after replacing IPM and a fuse on Z-sustain board, picture is great again, except this red pixel noise on black screen which becomes more noticeable when the set warms up. The noise is mostly noticeable in the up left corner and in the middle of the screen.
                              • Pipolups
                                Corsair K70 LUX RGB dying LEDs
                                by Pipolups
                                Hi there !
                                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                10-08-2024, 11:58 AM
                              • Lintesir
                                Panasonic P42S30 Plasma - Pink sparkles
                                by Lintesir
                                My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                There is about a 5cm high region at the top without any sparkles,...
                                07-26-2024, 03:16 AM
                              • THE GTC
                                Insignia NS-37D20SNA14 intermittent LEDs
                                by THE GTC
                                So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                11-03-2020, 02:40 AM
                              • Prosatanosz
                                Asus B85M-GAMER no hdmi output and random restarts
                                by Prosatanosz
                                Hi!
                                Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                                10-19-2024, 05:27 AM
                              • jimbofz
                                just a quick question do all qled leds appear blue when fault finding ?
                                by jimbofz
                                i have replaced many leds strips that have changed blue when they are worn
                                and the new replacements are perfect white
                                but when fault finding do quantum leds always look blue?
                                08-28-2024, 06:51 AM
