Sceptre X405BV-FHD3 Powers on, logo appears, then shuts off
  • juicedlime
    • Sep 2014
    • 30
    Re: Sceptre X405BV-FHD3 Powers on, logo appears, then shuts off
    Originally posted by johnboy1313
    I think bud was right with his initial diagnosis. Ccfl inside the panel or bad inverter.
    The inverters tested alright, I will go back to the Troubleshooting 2 Seconds to Black and attempt to test the CCFL's. I have a tv with a busted screen, that still came on, could I use a bulb out of it to do this?
    I'm going to try to jump the bulbs over, if I hit one and the screen stays on that should tell me which one is bad, if one is bad, or so I'm hoping. Will report back.
    • juicedlime
      • Sep 2014
      • 30
      Jumping them over and powering up only did the same thing it's been doing, flashing the logo then going black. So if the bulbs are bad, then my test didn't work and I need to get a spare bulb, or it's something else.
      • juicedlime
        • Sep 2014
        • 30
        Ok, so I figured I had nothing to lose, since it's already out of whack anyhow, so I just started taking a plug off, powering on seeing what happened and plugged it back in then unplugged another and so on, just seeing what would happen.
        Well, here's what happened, I pulled a connector that ran from the Inverter Board to the Main Board and it says CN4 on the main board, I am pretty sure I tested these points in CN4 with bud and it checked out, so I thinking the problem lies within the Inverter Board (the one with the three transformers), instead of a logo flashing and going back off, the logo fully lit for 5 seconds, and a box appeared after the logo disappeared which I believe states No Signal, something to that effect, and then the TV powers off again... I'm not sure if this is helpful to my case at all, but I felt it was worth sharing, and possibly eliminates something somewhere. If anyone can chime in please do, and thank you again for all of your time and patience.
          OK, we can try having one of the six lamp connected one at a time to see which one will not light up the screen, this is not 100% test to verify if the lamp is really bad or not but it may show us that one of the lamp may not light up.
          The screen will flash for seconds before it goes into safety shutdown, you will have to turn the TV off and move on the to the next connector and then turn the TV on, do that six times for all six lamps.
          • juicedlime
            • Sep 2014
            • 30
            They all equally flashed the same brightness, I was also able to see the Spectre logo in doing it as well. What was so shocking with unplugging connectors was when this 2 seconds to black is happening, it doesn't even seem as if it is Literally 2 seconds it just flashes and it's gone, but when I unplugged the connector the logo was fully there. I'm thinking it isn't the CCFL's, through reading the 2 seconds to black troubleshooting guide I read a spare bulb doesn't have to be the exact size so if all else fails I will break it down and start swapping bulbs. I figured the connector, since the pin's on CN4 checked out lead to something on that inverter board that is causing the problem, I'm just not sure what, then again I could be completely be barking up the wrong tree since I'm new to all of this thanks again bud
              CN4 is for feedback from the inverter board to tell if there is problem with inverter, lamps and tells the inverter circuits on the power supply board to go into shutdown, I am not sure what the normal voltage should be for the OVP, CNT-PRT, LD should be.
              • juicedlime
                • Sep 2014
                • 30
                I'm going to upload a photo of the logo when it pops up without the cord connected, I'm not sure if this is any count either of how it actually appears, or just because of the cord, but maybe it will shed some light.
                The images look garbled/discolored to me.. that could have something to do with the connector not being connected, I'm not sure how it all works.. just thought it might add insight or it may be nothing.
                • juicedlime
                  • Sep 2014
                  • 30
                  so what should I do?
                    I really do not know. You may try making test lamps.
                    https://www.badcaps.net/forum/showthread.php?t=19987
                    • juicedlime
                      • Sep 2014
                      • 30
                      I will check into that bud, thank you for all of your help and patience. I may also try to price a CCFL and see if it's within reasonable price range as well before proceeding since that may be what I"m looking at. Thank you again so much.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I was able to diagnose a bad transformer output on a 46" RCA on my bench by laying a loose bulb across the outputs of the transformers. Swapping the transformer moved the unlit spot on the bulb. Looks like I deleted my picture, but it looked very much like the picture in the first post.
                        https://www.badcaps.net/forum/showth...light=46la45rq
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          #32
                          I had a similar experience with the same type of symptoms on another TV. On the Main Board located somewhere near the EEPROM and Flash ICs there is a 14.31818Mhz Crystal. Replaced this crystal and TV started to work again.
                          • juicedlime
                            • Sep 2014
                            • 30
                            I will look into that. I have a 42" TV with good bulbs just a literal hole through the screen from a toy, if I read correctly on troubleshooting two seconds to black I can use that bulb to do a swap and see if they're all lighting. I think the inverter board for this TV is only $22, if it doesn't fix your TV are you allowed to return? I was leaning towards Ebay, but Shopjimmy.com has one as well. Thank you
                            • juicedlime
                              • Sep 2014
                              • 30
                              Andrew, I will research the EEPROM and Flash IC for this TV, as I'm not certain right off hand where those are located. Thank you again for your help and suggestions.
                              • juicedlime
                                • Sep 2014
                                • 30
                                Ordered a new inverter board since it was relatively cheap, the issue still persisted. I went ahead and dug deeper and opened the panel up to the CCFL's, and all appear to be fine. I'm not sure if they can appear to be fine and not be, but I will attach a picture of them all lit.
                                Not sure what to do from here
                                • juicedlime
                                  • Sep 2014
                                  • 30
                                  I performed this test on the new inverter board, it was evenly lit up all across, so the inverters are good.
                                  • gamethriller
                                    • Oct 2014
                                    • 153
                                    Bad eprom maybe?
                                    Or not bad for the wrong tv.....did you replace the mainboard?
                                    • gamethriller
                                      • Oct 2014
                                      • 153
                                      I replaced the eeprom on the new motherboard. I took the original eeprom from the bad board and now the tv works.
                                      • Super360
                                        Samsung/UN65H6300AF LOGO APPEARS AND SHUTS OFF
                                        by Super360
                                        Hi as you can see from title, I have a samsung tv here that will show the smart tv logo and then no picture after that even hitting input or menu on remote and shows nothing but the backlight still appears to be on. The tv will turn itself off after a minute or so automatically. I'm somewhat confused if this is either a eeprom problem or a bad led strip problem. The power supply makes a pretty noticeable humming sound when it's turned on leading me to believe one of the leds are shorted but idk honestly. Any of you guys have any help for me? I have a good multi meter and can take pictures of whatever...
                                        04-13-2024, 10:05 PM
                                      • events.b
                                        Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested good
                                        by events.b
                                        Hello, this TV currently has me stumped. As the title states, when I power on the unit, the backlight comes on for 1 second then shuts off. The TV is still on, and I can see the video if I shine a flashlight on the screen.
                                        Using the LED backlight tester I was able to confirm all LEDs are illuminating and seem to be working correctly when independently powered by this tester, so that leads me to believe there is something wrong with the power supply board.
                                        Perhaps the great minds here can help me figure it out, as I don't see any thing obviously wrong with it. The...
                                        02-08-2021, 11:03 PM
                                      • lowpost99@gmail.com
                                        Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                                        by lowpost99@gmail.com
                                        I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                                        09-03-2024, 02:57 PM
                                      • JaquesPratt
                                        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                        by JaquesPratt
                                        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                        07-16-2024, 01:04 AM
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
