Sony KDL-52EX700 amber and green lights blinks
  • NUTIN2LUZ
    • 61
    Issue that I am having before this happen was that I had 3 blinks. From the service manual it said it is possible that the BAL board was defective. I replaced the BAL board and now I am having a constant amber (timer) and green lights (power on) blinking at the same time. I posted a video of this happening. I also have the updated firmware on a USB stick and put in the service USB slot on the BAL board, still the same result. Any help would be appreciated.
    Here's the webpage of the blinking amber and green lights.
    http://vidmg.photobucket.com/albums/...s/MVI_9145.mp4
  • anmol
    • Mar 2012
    • 73
    • India
    Re: Sony KDL-52EX700 amber and green lights blinks
    u have format usb stick ? and then copy pest firmware.
    after that power off tv -put usb stick in slot. and power on tv and wait till tv restart?
    wbr
    • NUTIN2LUZ
      • 61
      wbr
      I formatted the USB stick to FAT32, extracted the file to the USB stick as directed on Sony's webpage. Installed the USB stick while powered off and pressed the power button. I've waited for 10 minutes and it still doing the amber and green light flash. Do I leave it on there longer?
      • NUTIN2LUZ
        • 61
        It's took about 45 minutes to complete the firmware.
          So TV is now fixed?
          • NUTIN2LUZ
            • 61
            Originally posted by tom66
            So TV is now fixed?
            Yes it is. Thank you to all.
              Thanks for the update, useful info.
              • Michegianni
                • Jan 2017
                • 3
                Sorry to dig up an old thread...
                I have the same problem on my KDL-55W800A.
                I had the red light blinking three times, after all checks in the service manual, proceeded to replace the BA2S board, now after powering on the TV, the green and amber status LEDs flash on an oscillating basis...
                I have downloaded the latest firmware from the Sony website, formatted a USB stick to FAT and copied to the root folder of the USB. The TV has now been on for about an hour, still no progress, just flashing amber, green, amber, green...
                When the TV powers up, the white status LED comes on, the panel LED backlight flashes for 1/2 second and then the green/amber starts flashing.
                Is there another way to "force" update the firmware on the TV?
                • Tommyblaa
                  • Mar 2017
                  Turn tv on without usb, turn on so lights are blinking and then insert usb. Should take about 3-4 minutes.
                  Thanks to all in the above thread had the same problem with
                  a KDL-55HX750.
                  3 red blinks- replace main pcb
                  after main pcb amber and green blinking continuous
                  install software
                  Working again!
                  USB was formatted FAT32
                  If still nothing try a different USB stick or downloading software again in case was corrupt.
                  Tommy - TV tech (Samsung expert) (Parts and service)
                  • Gruffe
                    • Aug 2017
                    • Sweden
                    a KDL-55HX750.
                    install software
                    Working again!
                    Will the TV blink in any way during the firmware installation?
                    As my KDL-60W605B stopped blinking after 3minutes...
                    As a second question, do I need to start the TV. Is it not supposed to start by itself?
                    • Farasa
                      • Jul 2016
                      • 47
                      • South-Africa
                      Hi
                      I have a Sony KLV32BX300 the green led blinks continually....any help will be appreciated
