Vizio VO320E no power
+ More Options
Posts
  • nodomo
    • Sep 2014
    • US
    First off, I have searched the forums a little bit and found lots of results for similar issues that I am having with my TV. However, I have absolutely no idea what any of the technical jargon meant. I have no experience with repairing TVs at all. The only limited experience I have is repairing XBOX 360 controllers. Please talk to me as if I know nothing about TVs besides how to turn them on and off and channel surf.
    The TV was given to me, and I took it knowing that it didn't work. I figured if I could fix it for less than $50, I'd have a nice little TV for super cheap.
    I've had it for a while, and decided to start looking into fixing it today. I took the back off of the TV, expecting to find some blown caps, but nothing looks out of the ordinary to me. There are no puffed ends on any caps, no burn marks on the power supply board, nothing. It does not turn on at all. No light or anything turns on when I click the power button.
    Here are a couple of pictures. I haven't done ANYTHING to the TV yet besides try to turn it on and take the back off.
    Where do I go from here?
    Re: Vizio VO320E no power
    Check the main fuse first, if it tested OK <1 Ohm reading), then check the DC Voltage right at the two legs of the main filter cap (big black cap laying on its side), it should have about 160~170VDC.
    BTW, do not touch anything on the board with your hands or body.
    • nodomo
      • Sep 2014
      • US
      Awesome, thanks. But...which is the main fuse? And what do I need to check it?
      Like I said, I am completely ignorant on this subject and know little to nothing about electronics as a whole.
        White cylinder with two legs soldered to the board next to where the power cord is plugged into, T 5A N 250V printing next to it.
        You need by digital meter for testing and you will be working on the line (HOT) deadly side of the circuit so you MUST be real careful!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • servobillŕ
          vizio VO320E-M BIN FILE (lg)
          by servobillŕ
          HELLO FRENDS
          I AM LOOKING FOR THE FILE FOR THIS VIZIO TV 32" since it is corrupt can you help me I can't find it on the net
          thanks for your reply
          11-11-2022, 11:48 AM
        • islandguy5
          Dead Vizio VO320E
          by islandguy5
          Good morning techs. Need some help. I have been in electronics for over 50 years but as you know it changes fast and left me behind.
          I have a Visio VO320E that is completely dead. I know it is old but if possible I would like to repair it to component level. I have located a few components that are bad and have ordered them from somewhere on the planet.
          I have circled the components that are bad. Two FETS and one Thermal resistor.
          I assume this has something to do with the display in some way. Any help would be great....
          11-15-2021, 07:34 AM
