AOC L32W761 bad TCON?
  • triplefour
    • May 2014
    • 1747
    seems the only question i have lately is whether its bad TCON or bad Panel!
    but here it is again... when i first turned on the tv i was getting a blank backlit screen...sound and buttons work....
    so i tried taking off one at a time the ribbon cables to the panel from the tcon.
    the videos show what it looks like:
    https://www.youtube.com/watch?v=Yvwqun_tFRs - both sides on
    https://www.youtube.com/watch?v=kbIW-1_lilY - one side off
    https://www.youtube.com/watch?v=ZCFukZSxCLA - other side off
    after doing this, now i dont get a blank screen right away...first i get some motion and some colored horizontal lines and then it fades to a blank screen.
    so, take a look at the videos n pictures n tell me what u think please.
    props to anyone who can guess what n64 game is playing...
    thanks!
    Don't fear the repair...
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: AOC L32W761 bad TCON?
    Looks like you might have atleast one bad cap.
    That's what you need to get sorted first.
    • triplefour
      • May 2014
      • 1747
      Good eye! I saw that but I figured since the tv turns on I get sound and backlights so isn't the psu ok for now?
      • triplefour
        • May 2014
        • 1747
        Could a bad cap on the psu really cause this symptom?
        • triplefour
          • May 2014
          • 1747
          ok i went ahead and replaced the TCON and that definitely was the problem because now everything works fine...only one small thing...there are 2 vertical black lines and one colored line on the panel. when i flex the panel a little i can get the colored line to go away but not the black ones.
          this is definitely panel damage?
            Yes, looks like a panel fault to me.
            • triplefour
              • May 2014
              • 1747
              and there really is no way to fix panel faults, ever?
                For the vast majority, including this, no.
                This TV would have had this problem before the other fault...
                • triplefour
                  • May 2014
                  • 1747
                  oh well... cant win em all. guess ill part it out and put em up on ebay thanks!
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • alltvrepairs
                    Lg TCon test pins for screen test
                    by alltvrepairs
                    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                    Appreciate your help....
                    06-13-2025, 06:33 AM
