What would cause a purple tint on the entire panel when turning on? When it would happen (not often) the tv would be cooled down as in overnight. All of the image would be there, but everything was in shades of pink/purple. Turning off and re starting after about 5 minutes, it would be fine. THANKS!
LG plasma 60PA6500-UA purple tint, entire screen, at startup
Cledus Snow: Can I ask you a question?
Bo Darville: Sure, ask me what?
Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.Tags: None -
Re: LG plasma 60PA6500-UA purple tint, entire screen, at startup
Just to add, I found one guy doing a You Tube video for Shop Jimmy mentioning a z sus possibly causing this. He was showing boards in a tv and what problems they could cause. Anyone else agree? Thanks!From my favoritest movie ever!:
Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money. -
Any takers on this?From my favoritest movie ever!:
Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.Comment
Likely Z-sustain, small chance of low Vsus on power board causing this too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Sorry for not getting back to you guys, I've got a lot going on lately. I do appreciate your help!
Thank you mmartell,
I looked before I started this thread but I didn't see anything like my problem. After reading your response I searched again, this time about discoloration. It does seem LG needed to work on their soldering robots. Mine has only done this several times, and then only after it was cold, after being off for several hours and only at startup, never while running for a while. Shutting it off for about 5 minutes and restarting would correct it. With #3 reading glasses and in the daylight, I looked at all of my boards front and back, paying attention to solder joints along with any other obvious problems. When I saw any suspect joints I gently rocked the component while looking at the solder joint but didn't see any movement. However I am new to this, I may have mis judged a joint.
Thank you tom66,
if this is a component issue on the z sus, which part, and would it be easily replaced? If the legs are very close together, I would need to work on my soldering skills first. I've also heared of multi layer boards which sounds challenging.
Low v sus? I checked all of the voltages listed on my panel label, I didn't see v sus listed. I do have vs listed, 205v reccomended, and at various areas on boards I do have 205v at the plugs where indicated.
I also have 2 of my fuses with 335v not listed on my label.
Should I run the tv with the back off so next time I can check voltages? (No kids are here)
Maybe use a plastic stick to push on parts on the z sus board?
Would it damage anything to run with a purple tinted screen while testing?
Many thanks to you both!!From my favoritest movie ever!:
Could you supply a photo of the problem?
The boards are single layer, easy enough to replace components on, but if you have never repaired one before yourself it may be hard so it could be better to simply swap the board.
You can run continuously in the purple state with no harm to the panel - I do not know about the electronics but it is probably not going to get any worse than it is already... You can also run with the back cover off and test voltages. Try checking Vzbias on the Z-sustain too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Interesting.... Not a Z-sustain fault, that's for sure.
Can you post a picture of the control board? It's the one in the centre of the TV, green in colour, connects to a lot of other parts...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Dodgy LVDS cable/plug/socket possibly.....?TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
I think this is it, is the LVDS cable the silver one? The terminals and plug pins looked clean. I didn't think to check if they were seated completely before removing for inspecting earlier. All ribbon connectors were removed and inspected without checking to be fully inserted first. I still have my training wheels on! If I need to generate the test pattern, I'll have to get back with you guys a bit later, I'll be away from home for a while. I had these pictures on my phone. Thank you guys!From my favoritest movie ever!:
The LVDS will be the cable that goes from the Mainboard,--one that has all the input sockets on etc, and that control-board....
Carefully remove the cable, wipe over the contact area of the cable with some contact-cleaner/WD/40 on tissue then refit--Do Both ends.....TELEFIX
Ok Alastair, I'll actually go back over all the ribbons as I think the WD-40 would be a good idea to prevent corrosion. Would it be a good idea to spray it into the ribbon sockets on the boards also? I can hold some paper towels around the plugs to avoid other areas.From my favoritest movie ever!:
No, no need to fill the sockets with the stuff--just a little on some tissue, wipe over is fine....TELEFIX
Ok, Thank You!From my favoritest movie ever!:
BTW, I don't like having leftover parts, and I did search for threads on this with no luck so I'll just go ahead and tell on myself here. During my removing and inspecting of the boards, I have forgotten where a couple of these soft rubber blocks came from. I don't have a picture as I'm away from home for now. I should have left them stuck to my panel, another rookie blunder. Is it possible they help dissipate heat? Maybe they go beneath heat sinks? They did come from under the boards somewhere. I haven't ran it yet.
Thank You!Last edited by Poor Flick; 10-30-2014, 06:13 PM.From my favoritest movie ever!:
Usually they leave a bit of adhesive mark where they were...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes Tom, we call that witness marks in my line of work, I've used that visual evidence many times working on school busses. I have no idea why I cleaned my panel and boards without note taking, marking or picture taking. That practice is common at our shop. So, now that I'm done, hopefully, painting myself into a corner, is it a fair guess they go under the heat sinks or would that be the opposite and be a heat insulator? When I get back home maybe see if my other boards still have any in place. It's been quite a while since I've worked on it and my memory isn't sharp anymore. Thank You!From my favoritest movie ever!:
They usually go underneath exposed connections, or transistors on the sustain boards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, once again many thanks, Tom!From my favoritest movie ever!:
This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...09-07-2024, 12:40 AM
by estabilitoHi, I've just repaired acer nitro an515-55 with specs:
i7-10750h, rtx2060.
Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
i've tried different bios, different vbios and same behaviour - clean windows install too.
Do you have any idea?08-13-2025, 02:52 PM -
by JohndillHi, I have a laptop panel model LP173WF4 which has suddenly got a green/blue like tint and purple lines, You can see in the picture with MS Paint that it is not a white screen and you can compare to the white in the monitor in the background. Is this fixable & if so, what can I do? Thanks :-)
It has been tested on a known good system & found to be a fault with the panel & not the system or cable....-
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
- Loading...
