bn44-00338b
  • still4given
    • Sep 2014
    • 24
    • usa
    Re: bn44-00338b
    You're right, I didn't notice that.
    How is this circuit supposed to work? Obviously 23mv won't turn on the MOSFET but what happens when the MOSFET turns on? Looks like it will force positive voltage onto the ground? You can see I don't understand how an SMPS works.
    So you still think the IC is the problem? I ordered some but likely won't see them for a week or so, coming from Hong Kong.
      Re: bn44-00338b
      Here is the application notes for the FAN7530, the example circuit is about the same as used in the board.
      • still4given
        • Sep 2014
        • 24
        • usa
        Re: bn44-00338b
        Hi Bud,
        I hope you are still monitoring this thread. My replacement IC finally arrived so I installed it. That wasn't the problem. I still have exactly the same voltages I show in post #17. For some reason the IC is not turning on. I have read through the docs for the IC and though I understand it a little better, I'm not sure what to look for as to why it is not turning on. Any other things you can suggest to look for?
        Thanks, Terry
          Re: bn44-00338b
          OK, so what DC Voltage do you get compared to the one in post 17?
          • still4given
            • Sep 2014
            • 24
            • usa
            Re: bn44-00338b
            Exactly the same, everywhere. I bought more than one IC so I even swapped in a second one. No change. The docs say the IC compares the inverted and the non-inverted inputs. I'll assume the inverted in the INV pin but I don't know which pin is the non-inverted. Something is not sending the correct voltage or current to make the IC happy. Have you had the chance to mark down the correct voltages for each pin on the IC? That would be very helpful.
            Blessings, Terry
            • still4given
              • Sep 2014
              • 24
              • usa
              #26
              Re: bn44-00338b
              I'm attaching another partial of the schematic with the voltages to hopefully give a better picture of what's going on.
              Thanks, Terry
                Re: bn44-00338b
                Can I see the bottom side of the board around the MOSFET and the IC you replaced?
                DP803 Diode (Gate discharge diode) is connected in parallel with low Ohms resistor so it will show conduction on both directions.
                Something is locking out the IC from generating the output signal to drive the MOSFET.
                • still4given
                  • Sep 2014
                  • 24
                  • usa
                  #28
                  Re: bn44-00338b
                  Here you go.
                  Edit; adding a shot of the bottom where I replaced the FSR
                  • still4given
                    • Sep 2014
                    • 24
                    • usa
                    #29
                    Re: bn44-00338b
                    Hi Bud,
                    I'm still hoping to fix this with some help. I hope you can find the time to take a look at my findings and make some more suggestions. I could just buy a replacement but then I won't learn anything.
                    Blessings, Terry
                      Re: bn44-00338b
                      I have to do more thinking on this one.
                      • still4given
                        • Sep 2014
                        • 24
                        • usa
                        #31
                        Re: bn44-00338b
                        I appreciate that. Standing by.
                        • still4given
                          • Sep 2014
                          • 24
                          • usa
                          #32
                          Re: bn44-00338b
                          Hi Bud,
                          Any more suggestions as to what I might check to help get to the bottom of this issue?
                          Thanks, Terry
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            #33
                            Re: bn44-00338b
                            Tried a new MOSFET...?
                            TELEFIX
                            • saularciga
                              • Feb 2014
                              • 55
                              • mexico
                              #34
                              Re: bn44-00338b
                              Hola, el problema que tienes esta en la linea que sale desde el diodo DP802, atraviesa BP803 y BP804 y continua por RP813, RP814,RP815,RP816, RP817,RP818 y RP819.
                              Mide estas resistencias, lo mas probable es que una de ellas esta abierta.
                              Cualquier variación fuerte de voltaje en la linea de entrada ( 120vca) provocara en daño del circuito o el daño de estos componentes.
                              Apagada la fuente o en standby , debes tener 180vcd aproximadamente 180VCD en BP803, con la fuente trabajando al 100% debes tener 380 - 400vcd
                              • saularciga
                                • Feb 2014
                                • 55
                                • mexico
                                #35
                                Re: bn44-00338b
                                See notes en datasheet in page 3:
                                The OVP comparator shuts
                                down the output drive block when the voltage of the INV pin
                                is higher than 2.675V and there is 0.175V hysteresis. The
                                disable comparator disables the operation of the FAN7530
                                when the voltage of the inverting input is lower than 0.45V
                                and there is 100mV hysteresis
                                • still4given
                                  • Sep 2014
                                  • 24
                                  • usa
                                  #36
                                  Re: bn44-00338b
                                  No, I have not tried that. Do the voltages indicate it is faulty?
                                  I don't quite follow you. INV pin is 1.1V which is higher than 0.45V and lower than 2.675V. I don't understand the term hysteresis nor how to check for that.
                                  Thanks, Terry
                                  • still4given
                                    • Sep 2014
                                    • 24
                                    • usa
                                    #37
                                    Re: bn44-00338b
                                    I ordered a new mosfet. I get back to you once I've replaced it.
                                    • still4given
                                      • Sep 2014
                                      • 24
                                      • usa
                                      #38
                                      Re: bn44-00338b
                                      Hi Guys,
                                      I installed a new MOSFET and have no change. Do any of you have a suggestion for where to look next?
                                      Thanks, Terry
                                        Re: bn44-00338b
                                        Nothing from me at this point yet.
                                        • still4given
                                          • Sep 2014
                                          • 24
                                          • usa
                                          #40
                                          Re: bn44-00338b
                                          I'd love to see a schematic with some voltage readings of other pertinent areas. If someone has one of these that they could take some readings one it would be most helpful.
                                          Thanks, Terry
                                          • DenK
                                            Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                            by DenK
                                            Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                            1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                            12-06-2024, 01:29 AM
                                          • dudochnicht
                                            Dell Inspiron 7520, LA-8241P mainboard problem, power on black screen
                                            by dudochnicht
                                            Hi, i have a Problem with my Dell Inspiron 7520 LA-8241P Mainboard.
                                            When i start it, all LED's turns on but the display is black.
                                            Shortly after starting I noticed a click on the mainboard but don't know where it came from.
                                            I have tested it with the i5 and after the click the laptop goes off but with the i7 the laptop stays on after the click .
                                            The Dell Inspiron 7520 supports the i7
                                            What I've already done:
                                            - start without RAM and it beeps 2 times
                                            - start without bios battery and it beeps 5 times
                                            - Press D on start,...
                                            10-24-2021, 06:43 AM
                                          • DemonBG
                                            Samsung QN82Q60R - locks up / Crashing / Unresponsive
                                            by DemonBG
                                            Picked this one up a few days ago. QN82Q60R. Screen works perfectly and sound works but after booting, the unit randomly becomes unresponsive to input (though whatever is on the screen will continue to play).
                                            Tried standard reset - no improvement.
                                            Tried service mode reset - No improvement
                                            Service menu is difficult to navigate as the unit regularly crashes / locks up which means i have to restart the set.
                                            Something i have also not seen before is that sometimes (not always) when i enter the service menu, i get an error "ERR by empty version Data....
                                            03-16-2024, 09:49 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • davidebeatrici
                                            Sony M851 MBX-217 no POST and restart loop
                                            by davidebeatrici
                                            Before proceeding with a component level repair, the usual troubleshooting process was followed:
                                            1. Disassemble and unplug everything except the power connector.
                                            2. Replace RAM.
                                            3. Replace CPU.
                                            4. Rewrite BIOS.
                                            Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
                                            After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
                                            I thought to myself "Well,...
                                            07-03-2025, 04:19 PM
