Matsui M32LW409 no picture but sound
    Re: Matsui M32LW409 no picture but sound
    There is a reason the engineers put two capacitors on there. Omitting one may work, but it could cause further issues down the line. The stability of the dc-dc converter could be affected adversely.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      They are local decoupling capacitors. It is common practice to put them, they are not 100% required. When repairing cellphones there are often problems caused by shorted capacitors. Trust me, nobody bothers to replace those little buggers. The offending cap is simply scraped off with a blade and the phone goes back to the customer.
      Replacing these capacitors is recommended but not mandatory. And you can use anything that fits in their place. They are not critical like on a power supply or VRM.
      A working TV? How boring!
        I do power supply testing at work. Usually using MLCCs. It's easily possible missing that capacitor could adversely affect the stability of the converter. They are not decoupling capacitors. They are the input capacitors for a boost converter (AVDD, 15V @ 1.5A.)
        It is OK for a quick test, but running continuously could cause a problem in the future.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          I wasn't saying he should leave the set running that way if it works. But it definitely can be tested like that, to check if it's good, or there are more issues.
          • Andyd1970
            • Feb 2013
            • 374
            • united kingdom
            Hi Guys,
            I tested the Caps with a meter CP1 it was O/C CP3 was short circuit with the meter on ohms. I replaced CP1 but still got the same no picture but sound, FP1 is O/C.
            I would like to replace the fuse and CP3 where do I find them on ebay? what value is the fuse and CP3?
            Thanks for all your help guys.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #26
              CP3 can be pulled from dead laptop boards or similar, check the ones near the input dc jack or near the battery connector. Any of those will work. For the exact value you can use a capacitance meter. As a guess, it should be 10uF 25v or 22uF 25v.
              For that type of fuse, the fuse's rating is printed on it as a code. The code "UD" solves to 3.15A. See here: https://cdn.badcaps-static.com/pdfs/...7263e74802.pdf. It seems to be SMD 0603 size.
              • Andyd1970
                • Feb 2013
                • 374
                • united kingdom
                #27
                Thank you,
                But where do I get those surface mount fuses? and what rating?
                  Do you not have a capacitance meter available, or a capacitance range on your multimeter?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #29
                    I have already mentioned, the rating of the original fuse is 3.15A. You can find them at any reputable supplier, like Farnell, Digikey and so on. You can also try ebay.
                      CPC sell packs of 10 for about Β£3 inc VAT. Min order Β£5 via card, free delivery, so throw a reel of Chemtronics solder wick on there (Β£2.50 inc VAT.)
                      • Andyd1970
                        • Feb 2013
                        • 374
                        • united kingdom
                        #31
                        Hi Guys, I have just used my meter which has a setting for capacitors and it indicated 23.3uf. So do I go for 23uf or 24uf?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #32
                          22uF is the standard size and that is what you should order. Some may measure higher or lower, generally higher. Regular capacitor tolerance is -20%/+80%.
                          • Andyd1970
                            • Feb 2013
                            • 374
                            • united kingdom
                            #33
                            Sorry to be a pain but just spoke to CPC who said they do not do the fuses would you be kind enough to send me the item number/link so I can order them, also the same with the caps as they said they have soo many to offer.
                            Thank you in advance.
                            Andy
                              Fuses
                              http://cpc.farnell.com/multicomp/mc0...-3a/dp/FF02260
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #35
                                The original fuse is 3.15A. A 3 amp fuse might blow for no reason after a number of power cycles. Sure, it's not that big of a difference, but it's better not having to pull the set apart again.
                                  It's being pedantic. Fuse failure rate is proportional to the square of the current. If you wish, they stock 4A fuses... it's generally bad practice to increase a fuse rating but I don't see harm being a likely outcome in this case.
                                  • Andyd1970
                                    • Feb 2013
                                    • 374
                                    • united kingdom
                                    #37
                                    Thank you so much guys for all your help, sorry to be a pain but can you send link to the correct capacitor as they asked all kinds of questions about the spec I needed.
                                    Thank you
                                    • Andyd1970
                                      • Feb 2013
                                      • 374
                                      • united kingdom
                                      #38
                                      Hi Guys,
                                      Order the 4amp fuse better to be safe than it blow again
                                      Capacitors I ordered the following, hope that are OK? I take it I should fit the 35v one and not the 16v one??
                                      http://cpc.farnell.com/kemet/b45196e...-bb45-00001003
                                      http://cpc.farnell.com/kemet/b45196h...-bb45-00001003
                                      If you could confirm that would be great and I will let you know once they arrive and I fit them.
                                      Thank you
                                        They are tantalums. They will work but you will need to be absolutely sure to get the polarity correct (if wrong they will usually violently burn.) You may need to bend the leads to meet the pads.
                                        • Andyd1970
                                          • Feb 2013
                                          • 374
                                          • united kingdom
                                          #40
                                          Hi Tom,
                                          Glad I posted that, or can you recommend a more appropriate capacitor from CPC ASAP so I can add to my order? Or how will I tell which way to fit them and which pad on the TCON is the positive or negative.
                                          Help
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                            I ordered a supposedly β€˜new' Tcon board this time, and
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
