Samsung QN75QN95B with One Connect
  • lotas
    • Jan 2016
    • 4908
    • Russia
    #41
    These modules have 5v DC/DC converters at the input to 3.3v and 1.8v to power the chips in these modules. Open any datasheet for any WI-FI/BT chip and look at their power supply.
    Also, USB modules receive 5v, and after the converters, the chip itself is powered.
    But this topic was not about the power supply of the Wi-Fi module at all, but about a short circuit on the 17v bus, and this Wi-Fi module had nothing to do with this breakdown.
    • Diah
      • Feb 2013
      • 6614
      don't change subject.. again wifi / BT VCC 5V. just stop to correct other with wrong way.. i was talking over this threat and the service manual opened at front of me. lets move on..for the future.
      • jason123
        • Oct 2015
        • 1156
        Ok HELP! these caps are 0805 size. One I just took off, measures 21uF!!!
        I'm assuming these are 22uF. however, I can't find X7R in that size. Could these by X5R? at 22UF, I'm only able to get 35V, not 50V. Will these work?
        • Diah
          • Feb 2013
          • 6614
          search after 22uf 50VDC MLCC SMD/SMT
          • jason123
            • Oct 2015
            • 1156
            I did.. Mouser and Digikey list the 22uF in at max V of 35V in 0805 Package - in X5R Dielectric only
            Where else do You suggest I search?
            • Diah
              • Feb 2013
              • 6614
              at yours scrap boards
              or ali
              • lotas
                • Jan 2016
                • 4908
                • Russia
                #47
                If 22x3=66, bet 15x4 or 10x6
                • jason123
                  • Oct 2015
                  • 1156
                  Not much room for stacking under the heatsink. I went ahead and ordered the 0805 22uF 35V X5R (2x the voltage rating of 17V - should be ok)
                  • Diah
                    • Feb 2013
                    • 6614
                    its your choice.. but its wrong for me,,, never do it ... .. you ignoring the Resistance between X5R and x7R.. waiting for the result after 1 month or more of daily working
                    • jason123
                      • Oct 2015
                      • 1156
                      You're correct, I would never use X5R. I'm thinking the currently installed caps are indeed X5R, and maybe that's why these have failed prematurely.
                      I've contacted Murata, Kemet, and awaiting TDK - None so far make an X7R in 22uF @ 50V (or 35V.) Leads me to believe the ones on the board must be X5R. Do you agree?
                      • Diah
                        • Feb 2013
                        • 6614
                        sure agree they dont make it,, but i gave you link at post #46 its exist
                        use just one from Mouser part 810-CAX7R1H686M670LH if you are hurry
                        • jason123
                          • Oct 2015
                          • 1156
                          Diah, the height of this part is 6.7mm and that doesn't fit between the board and the heatsink. Current caps are 1.45mm and there is barely any room between caps and heatsink. They actually placed tape between the caps and heatsink to prevent accidental shorting
                          • lotas
                            • Jan 2016
                            • 4908
                            • Russia
                            #53
                            TPS549B22
                            • Diah
                              • Feb 2013
                              • 6614
                              if so as you described any 22uf will be good even 35V
                              • jason123
                                • Oct 2015
                                • 1156
                                Repairs completed!
                                Thank you so much for the help. You guys are awesome
                                • lotas
                                  • Jan 2016
                                  • 4908
                                  • Russia
                                  #56
                                  Repairs completed!
                                  OK!
                                    Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                    This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                    09-07-2024, 12:10 AM
                                    09-07-2024, 05:50 AM
                                  • KYBOSH
                                    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                    by KYBOSH
                                    I picked this one up today.
                                    Previous owner says no signs of life.
                                    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                    The TV model is QN65LS03BAFXZA - version: CB06
                                    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                    Will keep you all...
                                    04-05-2025, 08:32 PM
                                  • atkallu
                                    Samsung One Connect Box SOC1001N vs SOC1004N
                                    by atkallu
                                    I am asking have somebody information about Samsung one Connect boxes compatibility ?
                                    So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                                    SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                                    Boxes part numbers are the same: BN68-08730A-00.
                                    07-09-2025, 01:54 PM
                                  • An-klamm
                                    Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                                    by An-klamm
                                    Hello!
                                    I have a TV that I can't get any further with.
                                    It is a Samsung UE 55HU8590 with one connect box.
                                    When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                                    As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                                    Since the TV works without ocb, I assume that it can't be the PSU?!
                                    I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                                    Is there...
                                    12-04-2023, 01:35 AM
