RCA (Thomson) F20TF10 in a coma
  • SteveNielsen
    Retired Tech
    • 2327
    Re: RCA (Thomson) F20TF10 in a coma
    I elected to try repairing the connector and connections on CRT board. I epoxied the connector shell to the board and it is solid. Connections from the main board through the cable and the pins on the CRT board connector are good. I soldered thin wires to replace borken traces on the CRT board and continuity checks are all good.
    Before I reconnect everything and test again I want to ask if it is ok to leave the Gem Star 4 board disconnected? I've never used that function and I won't.
    • kasfamily
      • Aug 2014
      • 765
      • Russia
      #122
      Hi SteveNielsen, welcome back! I do not know what it Gem Star, but perhaps control processor needs information about the board and its serviceability.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4923
        • New Zealand
        #123
        No idea but this: http://www.justanswer.com/tv-repair/...el-remote.html suggests it's OK, at least for that model.
        -David VanHorn
        • SteveNielsen
          Retired Tech
          • 2327
          Thanks for the link Agent. I'll try it unplugged. It uses those plastic film ribbon cables that like to come out of connectors and/or break.
          Hi Kas. Gem Star (or Gemstar) is a TV Guide service that tells you all about what's on TV channels sort of thing. I don't think it's available where I live and even if it was I'd never use it.
          Well, anyway, I got the junk all plugged back in and same story, no HV to the CRT, no low voltage turning on. It made no difference having the Gemstar unit plugged in or not. All the previously measured voltages are the same as last time:
          IP330
          Pin 1 = 10.4v
          Pin 2 = 0v
          Pin 3 = 8.6v
          TP390
          E = 0v
          B = .5v
          C = 8.7v
          TP391
          E = -.01v
          B = .67v
          C = .03v
          Oh yeah, I also touched up all the solder joints in the area of the flyback.
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            #125
            Check the voltage at DP57 (+14VE) and again "need photo area board from N to R and 0 to Z, with two sides. What would follow the chain of signal control base TP391"
            • SteveNielsen
              Retired Tech
              • 2327
              DP57 = 12.5v but is not the same as +14VE, +14VE is 0v.
              edit: I may be measuring the wrong point for +14VE, I tested the point directly above the printing, however the point to the right has 12.5v and does trace back to DP57.
              These are the best pics I can get. In trying to trace out the paths I get lost under the printing in the n/p x 1 area.
              edit: that was tracing the emitter of TP390 though.
              • kasfamily
                • Aug 2014
                • 765
                • Russia
                #127
                DP63 cathode must be 14V, while the inlet and IP330 is 12V and the output level 9B. So this very little 12.5V. It is necessary to check the CP64 and Zener DP57
                • SteveNielsen
                  Retired Tech
                  • 2327
                  CP64 is a 3300uF 16v and tests 3026uF, 2.8 ohms ESR.
                  DP57 tests ok. It reads as diode, Uf 807m, 32pF.
                  (I don't know what "Uf" is supposed to mean on this tester for a diode, forward voltage? In transistor testing with this tester Uf indicates base-emitter threshold voltage. I assume that it is indicating that the forward voltage is 807mv.)
                  I also checked C62 (470uF 25v) which reads 450uF, 3 ohms ESR.
                  edit: both caps are 85c
                  edit: corrected typo in line 1 to read 2.8 ohms, not .28 ohms.
                  • kasfamily
                    • Aug 2014
                    • 765
                    • Russia
                    #129
                    DP57 painted as zener.UF807m can not find in the series UF800 not http://pdf1.alldatasheet.com/datashe...TE/UF806F.html. And as the voltage DP63 cathode?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4923
                      • New Zealand
                      #130
                      UF807M is not the model, he says his tester shows 'Uf 807m" which is probably the forward voltage.
                      In a switching PSU around 3 Ohms ESR would be terrible. Here where they use general purpose capacitors it may be more acceptable, but a 3300uF should test lower.
                      Check this ESR table (http://www.jestineyong.com/esr-meter-table/):
                      -David VanHorn
                      • kasfamily
                        • Aug 2014
                        • 765
                        • Russia
                        #131
                        Thanks Agent24 for the correction, and I look very tired search diode UF807m
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          I'm sorry about that Kas. Thanks very much for the effort.
                          Thanks Agent, I figured 3 ohms was pretty high for it too. The 470uF ESR is pretty high too. I have a lot of gp caps in my collection, I'll look for replacements.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            False alarm, my cheap ESR meter wasn't working right, needed new battery. The caps are ok after all.
                            • kasfamily
                              • Aug 2014
                              • 765
                              • Russia
                              #134
                              I did for the ESR meter external power supply used for this charging adapter from a cell phone. Just tired of changing batteries.
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                I might do something like that. It wasn't just the battery either, I was using cheap alligator clip test leads that weren't making good contact. They haven't given me much trouble like that before but I suppose it mattered more when the battery got low.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4923
                                  • New Zealand
                                  #136
                                  It makes me think though, maybe you should check all the capacitors in the power supply.
                                  I had a fault in my own TV last week where two capacitors went open-circuit on the -23v rail resulting in a huge amount of ripple on that rail. In turn, that caused the RGB amplifiers to fail to operate correctly and the picture to vanish.
                                  -David VanHorn
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    I've already checked the PSU caps but am thinking of checking all the caps.
                                    I found the source of the hissing sound though, it is the transformer in the lower center of the board near the power supply. I used a modified stethoscope to find it.
                                    • kasfamily
                                      • Aug 2014
                                      • 765
                                      • Russia
                                      #138
                                      If the source of the noise LP02, it may be damaged by the ferrite core inductor
                                      • kasfamily
                                        • Aug 2014
                                        • 765
                                        • Russia
                                        #139
                                        Here is a small example of how customer to look for the noise in the power supply and also thought that the noise transformer and even delayed his wire. A faulty filter capacitor 47uF turned 400V - he was just broken one pin. While the receiver was working, was only affected by noise from the power supply.
                                        • SteveNielsen
                                          Retired Tech
                                          • 2327
                                          It is LP03 that hisses, the one with the yellow around the frame and copper strap. It's marked
                                          VDE (in triangle) 2114390 FEC 0105c
                                          SRV3906-010
                                          Searching on any of those numbers has no results.
                                          • edugimeno
                                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                            by edugimeno
                                            Hi!!
                                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                            At a certain point, moving stuff around, I put all wires back in place and...
                                            03-24-2024, 02:31 PM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            by sam_sam_sam
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                            Thomson NEO 15 WWN15I5-8BK1T Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO 15 WWN15I5-8BK1T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWN15I5-8BK1T boardview and WWN15I5-8BK1T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 06:21 AM
                                            Thomson NEO X14C WWX14C4BL64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4BL64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4BL64-P boardview and WWX14C4BL64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            Thomson NEO X14C WWX14C4PK64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4PK64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4PK64-P boardview and WWX14C4PK64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
