RCA (Thomson) F20TF10 in a coma
  • SteveNielsen
    Retired Tech
    • 2327
    Re: RCA (Thomson) F20TF10 in a coma
    Thanks, that is what I've been doing, taking pics and tracing out on the computer screen, traces are too hard to see otherwise. That collector connection goes all over the place through jumpers galore.
    You'll have to bear with me though, I have a 9 year old daughter who keeps swiping my camera. Plus I can only spend limited time looking as it hurts my old arthritic neck. I'll keep you updated as I find out.
    • SteveNielsen
      Retired Tech
      • 2327
      Sorry for the delay. Here are some pics of that area that are clearer I think.
      • kasfamily
        • Aug 2014
        • 765
        • Russia
        #103
        I study photos. IP301 now is voltage on pins ?
        • SteveNielsen
          Retired Tech
          • 2327
          Yes, IP301 still has proper voltages; 9.2v on pin 1 and 5.9v on pin 3.
          I've got some of the circuit traced out from pin 26 on the video chip but not completely. So far it goes nowhere near the flyback.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            #105
            Is that bulging cap opposite the crystal and just above to Main IC??? I see Qio2 next to it but that isn't the label it should be Cxxx.
            • kasfamily
              • Aug 2014
              • 765
              • Russia
              #106
              Need actual voltage IP330, TP390 and TP391
              • SteveNielsen
                Retired Tech
                • 2327
                Andrew, the cap isn't bulging, it's the lighting and shadows. It's labeled CV28 on the other side of the cap.
                Kasfamily, here are the voltages:
                IP330
                Pin 1 = 10.4v
                Pin 2 = 0v
                Pin 3 = 8.6v
                TP390
                E = 0v
                B = .5v
                C = 8.7v
                TP391
                E = -.01v
                B = .67v
                C = .03v
                When measuring TP390 I accidentally shorted B to C which turned on HV to CRT anode.
                Last edited by SteveNielsen; 10-15-2014, 06:37 PM. Reason: Corrected; I shorted Base to Collector on TP390, not Emitter.
                • SteveNielsen
                  Retired Tech
                  • 2327
                  TP390 has already been tested ok out of circuit.
                  I just pulled TP931 and it tests ok as well.
                  My accidental short of B-C on TP390 turning on HV tells me something is not turning that transistor on.
                  Wish I had a schematic for this board.
                  • kasfamily
                    • Aug 2014
                    • 765
                    • Russia
                    #109
                    OK!TP391 controls the supply of 9 volts on pin 26 TA1268 through TP390. Enable signal is applied to the base TP391(may be to press POWER button). If not, need photo area board from N to R and 0 to Z, with two sides. What would follow the chain of signal control base TP391
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Yes! Pwr button now functions! WIth the set off though I can still hear quiet hissing but unable to pinpoint it yet.
                      I am able to test the CRT, turned screen control up enough for dimly lit screen, shorted pins 6, 8, 11 and got fairly bright Green, Blue, Red. If the short gets' left on a pin for more than a second or so the set shuts off again. I assume that is normal in this test.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        The TV will now come on using Pwr button and will show a full screen of snow for about 1 second then shuts down. If I press a menu button after powering on the menu appers but blinks and image gets vertically squashed then TV shuts off.
                        • kasfamily
                          • Aug 2014
                          • 765
                          • Russia
                          #112
                          Very good headway! Maybe will take a photo of the screen, but I not clear get all.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            Something else just went wrong, the screen is all white with retrace lines now even with screen control all the way down, turning it up it gets brighter and will shut off if turned up past a point.
                            • kasfamily
                              • Aug 2014
                              • 765
                              • Russia
                              #114
                              Reported connector connected?
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                It's connected ok. The white screen started after I nudged the blue elecrolytic next to the flyback transformer when the set was on. I've pulled the cap and it checks ok. I'm looking for bad solder joints, etc. in that area but see nothing out of the ordinary yet.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4919
                                  • New Zealand
                                  #116
                                  Might pay to just resolder everything in that area just in case, sometimes they're not easy to see.
                                  I also noticed in a previous photo that capacitor is right up against a ribbon cable, perhaps it was not the capacitor being bumped but rather the capacitor bumping the wire?
                                  -David VanHorn
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    That's a good call Agent24, in fact that cable had a bad contact at the CRT board on the same connector (BU004) that I repaired lifted pads/traces for, but it seems to have been the connector itself not quite seated and that problem is gone now. Now I'm kind of back to square one with HV but nothing on the screen, except the power button still works. I am going to touch up the soldering as you suggest.
                                    • SteveNielsen
                                      Retired Tech
                                      • 2327
                                      Well folks, my repair of BU004 on the CRT board has failed. The stress from the stiff cable was too much for it plus I think the contact pins inside the plastic connector shell got mispositioned due to heat from soldering. I guess I could try eliminating the connector, strip back the cable and hardwire it to the board but I'm concerned that would suffer the same fate and tear the traces again unless I glued it down or provide some sort of strain relief for it.
                                      • kasfamily
                                        • Aug 2014
                                        • 765
                                        • Russia
                                        #119
                                        May be necessary to replace or extend the cable to the BU004. Use for this the softer and more flexible wire.
                                        • SteveNielsen
                                          Retired Tech
                                          • 2327
                                          That's a good idea. Thanks. I'll see what I've got that's suitable.
                                          • edugimeno
                                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                            by edugimeno
                                            Hi!!
                                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                            At a certain point, moving stuff around, I put all wires back in place and...
                                            03-24-2024, 02:31 PM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            by sam_sam_sam
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                            Thomson NEO 15 WWN15I5-8BK1T Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO 15 WWN15I5-8BK1T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWN15I5-8BK1T boardview and WWN15I5-8BK1T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 06:21 AM
                                            Thomson NEO X14C WWX14C4BL64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4BL64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4BL64-P boardview and WWX14C4BL64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            Thomson NEO X14C WWX14C4PK64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4PK64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4PK64-P boardview and WWX14C4PK64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
