LG 55UP7000PUA washed out and dim
  • x_orange90_x
    • May 2015
    • 762
    Originally posted by Diah
    could be... but need to test ESR of caps.. about LED BL.. download or generated on windows paint UHD pxsel Photo R G B at value 255 , ir download from web there are so many test picture...
    I did a color test video from YouTube last week and recorded it. I've attached it.
    • Diah
      • Feb 2013
      • 6550
      this is not LED issue.. do you have service remote ? i would like to do firs sendingt IN_STOP. then if nothings change to better need to open service menu E_Z Adj to check entry
      • b0ba
        • Mar 2018
        • 14
        • Ukraine
        *del*
        • x_orange90_x
          • May 2015
          • 762
          I do not have one, but I could order one from Amazon if necessary.
          Edit: I just ordered a service remote. It should come tomorrow. What should I do when I get it?
          • Diah
            • Feb 2013
            • 6550
            when you have service Rc at yours hand you will understand my POST #22
            • RetroComputingGrotto
              New Toy UNI-T UTi260B - What Settings?
              by RetroComputingGrotto
              I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
              After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
              I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
              09-02-2025, 08:36 AM
            • i440bx
              Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
              by i440bx
              Hey there,
              I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
              The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
              It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
              As written above, I plugged in a new CMOS cell and checked...
              08-19-2024, 02:28 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • max789
              Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
              by max789
              Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
              I made the following tests:
              1. Disconnected the main board from Power Board = backlight works.
              2. Connected the main board and disconnected the T-Con = backlights does not work.
              So I ordered a main board from Ebay also BN41-02156A but from...
              01-18-2024, 06:56 AM
            • bpcannan
              VIZIO M557-G0: Backlights or ???
              by bpcannan
              'Morning,
              I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
              Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
              I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
              I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
              10-29-2023, 06:36 AM
