Badcaps - what do you think - un46b6000vf samsung
  • zdsh07p9
    • Nov 2013
    • 155
    I have the opportunity to buy this TV for a decent amount. What do you think could be wrong with it? Pic Below
  • zdsh07p9
    • Nov 2013
    • 155
    Re: Badcaps - what do you think - un46b6000vf samsung
    + Budm I checked the guides you gave me the other day and couldn't specify which category this would go in from the examples
      it is a bad panel, stay away.
      • zdsh07p9
        • Nov 2013
        • 155
        Thank you - I will steer clear of this one
        • Shinju
          • Mar 2014
          • 1239
          Well wait. If you can get it for cheap/free get it for parts. These are common panels and parts are not cheap to buy if you come across one that has a bad not repairable PCB in it.
          Just my 2 cents.
          • zdsh07p9
            • Nov 2013
            • 155
            I wish I could get it for free. I talked this guy down from $250 (INSANE) to $50 but if it has a bad panel then I don't think I could do $50 for it because the parts aren't too bad (compared to some others Ive bought)
            • Shinju
              • Mar 2014
              • 1239
              250! Oh wow the seller is delusional! Yeah I would run 50 is meh if you don't do high volume repairs.
              • DemonBG
                • Mar 2012
                • 143
                This one MAY be a bad main board as well - I had a similar (not exactly the same) issue on a C series TV which turned out to be a faulty main board:
                https://www.badcaps.net/forum/showthread.php?t=37133
                Good luck,
                Demon
                • Shinju
                  • Mar 2014
                  • 1239
                  ^ I think your display error is different, did your lines bleed down or were they solid as soon as you turned on the Panel?
                  I had this Panel in the 7000 series and mine did exactly what the op's panel is doing
                  https://www.badcaps.net/forum/showthread.php?t=38822
                  Yours looks like the one I have here now its a 55C650 that fell off a wall mount and ripped the Coaxial input right off the board and damaged the LVDS connector output on the main board.
                  When I fired this one up it worked fine but had every other pixel rainbow line and after 5-10 min of use it would go away I thought it was a bad panel and was about to toss it / part it when I discovered the LVDS connector being loose. I applied pressure while it was on and the lines went and came when I released pressure.
                  Trying to find a mainboard for it now but there is nothing for sale for it anywhere!
                  • zdsh07p9
                    • Nov 2013
                    • 155
                    He was extremely delusional, I think ill tell him that if he will come down to $20 Ill come pick it up tonight and check it out. But its really difficult for me to sink anymore into it. So would you pick it up for $20 as a low quantity repair person?
                    • zdsh07p9
                      • Nov 2013
                      • 155
                      btw - I found a main board on ebay but its $129.99 OBO
                      • Shinju
                        • Mar 2014
                        • 1239
                        I would take it for 20.00. If the mainboard tests out good that's an easy 90-100.
                        • zdsh07p9
                          • Nov 2013
                          • 155
                          More pictures if they help
                          • zdsh07p9
                            • Nov 2013
                            • 155
                            Very true, The power board must be good still - im guessing.
                            • Shinju
                              • Mar 2014
                              • 1239
                              I am 90% certain its a bad panel, if you get it break it down to the tab bonds and apply pressure to the TFT board or gently to the IC bonded inside the ribbon cables and see if it changes. (There is quite a few tab bonded ribbon cables that are fused to the glass/TFT buffer board)
                              Use a piece of rubber or something nonconductive, the one I had I ended up parting it out to a local who needed parts for his with a good panel.
                              • zdsh07p9
                                • Nov 2013
                                • 155
                                the TFT board is the boards that connect to the LCD via the tab bonds? or are those the IC drivers
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  ^ yes there should be a TFT board for left and right after the T-con. Let me see if I cannot dig up a photo of the 7000 I had.
                                  • zdsh07p9
                                    • Nov 2013
                                    • 155
                                    Oh okay, I know what youre talking about now, I just had an e601i-a3 that had a vertical blue thin line on it that I tried that with. BTW if anyone needs parts to e601i-a3 I have 2 working main boards, 2 working t cons, and a power supply + remote control for it haha.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      Sorry for the blurry photo the iPhone decided to focus on the screen more then the tabs.
                                      • zdsh07p9
                                        • Nov 2013
                                        • 155
                                        Ahh no problem. I see them though, Thanks for all your help. I will need more soon im guessing !
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          09-07-2024, 05:50 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • Francisco.s
                                          Samsung Galaxy Book NP750XED
                                          by Francisco.s
                                          Hi, need bios for Samsung Galaxy Book NP750XED-KC4ES.
                                          This board mounts a intel alder lake, and seems that the bios is corrupted.
                                          I tried two versions of flash image tool 16, and shows some errors and can't open it.
                                          This are the errors:
                                          Command Line: X:\MEA\FIT 16.0.15.1531\fit.exe
                                          INFO : Start decompose 'X:/MEA/samsung.bin' image.
                                          INFO : MFIT version used to build the image: 16.0.15.1554
                                          INFO : Generate layout dictionary <xpath, container wrapper>
                                          INFO : Layout dictionary generated successfully
                                          ERROR...
                                          06-17-2024, 12:48 PM
