Samsung UE46C6530 Vertical colored lines accross screen
  • DemonBG
    • Mar 2012
    • 143
    So yesterday i picked up this UE46C6530 LED TV as i was after a C series main board (BN41-01444) for my other TV which was on the bench... (https://www.badcaps.net/forum/showth...t=35344&page=2)
    The seller described the fault as "Vertical colored lines" on all inputs and also in the image diagnostics so i assumed it was a panel / T-Con / AV fault (The dark smudge in the top left corner is the cling film the tv was wrapped in).
    I was hoping it was not a panel fault as the lines covered the full width of the screen; not just discrete portions and the line colors didn't change with the picture behind them - This made me think this MAY be a T-Con or AV issue?
    I remember seeing something similar on a laptop which needed a GPU reflowing (broken solder joints under the GPU chip) So i started pushing on each of the 3 heat-sinked SMC's on the AV board...lo and behold, as soon as i put some pressure on one of the chips (highlighted in red) the image cleared up... and went back to funny lines as soon as i stopped applying pressure.
    Has anyone had anything like this happen before? Any suggestions as to how i can fix it? Unfortunately the main boards are fairly rare/ Pricey!
  • wills123
    • Jan 2014
    • 72
    • england
    Re: Samsung UE46C6530 Vertical colored lines accross screen
    cold soldee joints under bga chips is very common. If anyone local to you has rework equipment they may reflow or reball it for you at not too much expense. You could heatgun it but theres always a risk you will kill the chip/board when heatgunning things. leadfree solder needs to be around 217c to be reflowed
    • DemonBG
      • Mar 2012
      • 143
      Hi wills,
      Thanks for the reply. Is that the BGA Chip then?
      I will look around and see what my options are... i have previously successfully reflowed some equipment in my microwave oven (set to the oven mode... Obviously) but dont want to subject everything to the heat...
      • wills123
        • Jan 2014
        • 72
        • england
        it looks like it has the solder balls underneath it from the photo to me, the fact you press on it an all works ok, points to cold solder joint under it Yeah ive heard of people ovening things but wouldnt reccomend it lol. i have ir rework machine though so have it easy lol
        • DemonBG
          • Mar 2012
          • 143
          lol i bet that makes life a little easier then :P I dont suppose anyone could purchase out your reflowing services could they? ^^
          • DemonBG
            • Mar 2012
            • 143
            Update
            Just a quick update - I did a heat-gun reflow (did lots of research and hopefully did a decent job of it using flux and a IR thermometer) and the vertical lines cleared up!
            Been using the same board in a different TV for about a week now and so far so good... I also added a few more thermal pads to maximize heat extraction out of the surrounding components and keep everything cooler....
            Thanks for the help all and hope this helps everyone.
            Take care,
            Demon
            • theop
              • Nov 2013
              • 1
              • korinth
              hi demon bg i have the ue32c6500 Samsung led TV and i have the same problem
              Vertical colored lines across screen. Ι know that is the same bga for sure because pressing the left bottom of the chip the lines disappear.
              Can you please tell me what specific tools you use and the prossess of doing the re flow
              like the way of heating like min temperature celcious
              if you have any video of doing it wil also help
              thanks in advance
              Theo
              • ABMaster
                • Nov 2015
                • 5
                • ITALIA
                I havent a led Tv but a Plasma ps42c96hdx with 2 vertical bar diplayed
                the Power Supply is Ok
                what can be the logical??
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Start a new thread with PICTURES !
                  • mohammedgladiator
                    • Mar 2016
                    • 17
                    • palestine
                    what the reason of this vertical line https://www.youtube.com/watch?v=AzpFNRXsKjw please help me
                    • mohammedgladiator
                      • Mar 2016
                      • 17
                      • palestine
                      please help me with this vertical line http://www.avsforum.com/forum/attach...5&d=1456849260
                      • Stanley1843
                        Screen Display Vertical Multicolor Lines
                        by Stanley1843
                        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                        06-29-2024, 11:54 AM
                      • pni
                        LG 49uf695v vertical coloured lines
                        by pni
                        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                        11-14-2025, 03:15 AM
                      • Falki
                        Colorful LCD Vertical Lines on Samsung ue55es8090
                        by Falki
                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                        Sadly it has vertical lines at the left and one line in the middle-right.
                        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                        I have factory resetted the TV as well but also with no luck.
                        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                        A similar issue has been posted as well but also with no actual response ...
                        08-12-2025, 04:19 AM
                      • visionbluedemon
                        Help. Sony kd-65x85dj vertical lines
                        by visionbluedemon
                        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                        tried blocking LC lines too, but same results
                        is it lcd panel issue or tcon board issue?...
                        07-25-2025, 04:56 AM
                      • gpo23
                        Sony KDL-40V3000 - Vertical lines
                        by gpo23
                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                        With the new t-con the color are good but there are vertical lines on all the screen :
                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                        Is there a way to fix the vertical lines on the new t-con ?
                        Thank you for your help
                        gpo23...
                        10-04-2023, 09:11 AM
