kdl-40nx723 e double image help please
  • wreksta
    • Aug 2013
    • 508
    • england
    DOES ANYONE KNOW WHAT CAUSES THE
    double image problem on my 3d tv
    I will get a picture
    but basicly its like this
    all wording and images are doubled
    3d display
    3d display
    3d depth adjustment
    3d depth adjustment
    that's an example
    ive tried updating firmware etc any ideas could this be hardware related
    please help
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: kdl-40nx723 e double image help please
    after removing left side screen ribbon my picture fades away
    when I remove my right side ribbon the left side of screen is perfect
    if I put both ribbons back im left with double image
      That sounds like a bad LCD panel to me. If the image is OK with one ribbon out, it's usually the panel (I can't recall a case where it is not.)
      • wreksta
        • Aug 2013
        • 508
        • england
        tom anything else it could be ideas please it just went like this
          +1 bad panel.
            I think it's scrap, sorry :/. You're welcome to try fiddling with the tab bonds of course, but since it just "went" I doubt it'll be fixable.
            edit: Now I'm home and I see the picture, I would definitely say panel is bad.
            • wreksta
              • Aug 2013
              • 508
              • england
              tom ,bud why do you say this straight away could the connections from tcon to driver board noit be bad I aint checked this yet could be a bad ribbon etc
              • kasfamily
                • Aug 2014
                • 765
                • Russia
                a panel name in the tv ?
                  Because we've seen it hundreds of times and it is always a bad panel (so far I believe without a single exception.) You could rule out your ribbon problem by swapping the two ribbons over. (Do NOT connect left to right, but just swap the cables on both sides.) However, I doubt they are the fault.
                  When you unplugged one half, you removed whatever was faulty on one half of the panel that was loading a signal line down. (read: shorting an important signal.) I am not sure what exactly is failing, but it is probably one of the driver ICs on that part of the panel.
                  Modern LED-LCD TVs have shockingly high rates of panel failure. Next to open-circuit LED (a bloody difficult one to fix!), it seems to be the most common fault (...one of the reasons I prefer fixing plasmas.)
                  I bet this TV has Samsung (S-LCD) or AU Optronics panel.
                  • anmol
                    • Mar 2012
                    • 73
                    • India
                    Here is panel id list.
                    wreksta wrote,
                    may be VGH-VGL voltage problem there.
                    pls. post T-con pic.
                    Regards
                    • wreksta
                      • Aug 2013
                      • 508
                      • england
                      so there could be hope
                        I don't know what anmol wants you to test but I'd suggest supplying the T-con picture for them.
                        I had a "noisy" picture issue caused by VGL fault (T-con), however it was completely different to yours, and mine was the same regardless of the ribbons (noisy picture either way.)
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          tom what is this vgl fault any ideas what to test please
                            It's a voltage on the T-con board, marked by a test point VGL or VOFFE.
                            Should measure around -5V to -10V (black on chassis, red on test point)
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              thanks tom will test now
                              • wreksta
                                • Aug 2013
                                • 508
                                • england
                                Tom vofee test point is 11.7 volts any ideas is there tab bonds down the sides mate
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  Is that voltage correct
                                    Is VOFFE negative? Does it change with the ribbons one at a time, or both in? If that is OK, then it rules out a VGL problem on the T-con board (so it probably is not a T-con problem but panel related.)
                                    On these newer panels there usually aren't bonds down the side of the screen, they are now built into the glass (which should be more reliable, time will tell.)
                                    • anmol
                                      • Mar 2012
                                      • 73
                                      • India
                                      here is tcon pic. and voltage.
                                      pls. check if your tcon board is same as pic.
                                      SM4109
                                      VIN - 12V
                                      HAVDD - 8.25V
                                      VCC33 - 3.3V
                                      VOFFE - minus 7.4V
                                      AVDD - 16.5V
                                      VONE - 28.6V
                                      VCC12 - 1.2V
                                      VCOMG3 - 7V
                                      7V VCOMG2B
                                      INA- - OUTA 6.6V - 6.4V
                                      INB- - OUTB 7V - 6.6V
                                      RST - 3.3V
                                      OUTC - 8.6V
                                      Regards
                                      • wreksta
                                        • Aug 2013
                                        • 508
                                        • england
                                        hi I cant find half of those voltages
                                        tom can you explain how to do this negatively
                                        running tv as it all cables connected
                                        I get these
                                        havdd - 8.53v
                                        vcc33 - 3.3v
                                        voffe - 11.7v
                                        avdd 17.1v
                                        vone - 30v
                                        vcc11 1.2v
                                        ina 7.3v
                                        outa 7.3v
                                        inb 0.96v
                                        outb 1.0v
                                        from what I can work out here these don't look right to me
                                        help me out I cant seem to find
                                        rst
                                        outc
                                        7 vcomg2b
                                        vin
                                        vcomg3
                                        • howardc64
                                          TCL 49S405 double image
                                          by howardc64
                                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                          06-23-2025, 03:20 PM
                                        • Cornito
                                          Samsung UE55RU8000 reboot and then double image after heating up
                                          by Cornito
                                          Hello team,
                                          I'm back with another tv and another problem.
                                          I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                          First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                          Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                          Then double image reduce in height and move to the top.
                                          The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                          When I...
                                          03-31-2024, 01:37 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • piershs
                                          Toshiba plasma 50WP16 wierd double image fault
                                          by piershs
                                          My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                          Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                          • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                          • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                          08-01-2020, 01:07 PM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
