Samsung QE50Q60TAU - Flashes black/blue screen
  • ulthi
    • Oct 2025
    • 6
    • Danmark
    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
    I have tried different resets and have also replaced the main board - but nothin has changed.
    Any suggestions?
    https://youtu.be/acYQ-ImmhWA
  • Diah
    • Feb 2013
    • 6460
    50 size Panel over all brand bad and have issue... so just put back yours original MB and post clear photo of it and the whole back of the set
    • ulthi
      • Oct 2025
      • 6
      • Danmark
      Hi
      Here is a photo Hope it helps
      • Diah
        • Feb 2013
        • 6460
        Originally posted by ulthi
        Hi
        1-put jumper between the 2 feedback point on MB
        2- disconnect the U ribbon cable .. you may found another U ribbon cable under the left speaker
        you will see in which side of panel had defect
        • ulthi
          • Oct 2025
          • 6
          • Danmark
          Click image for larger version  Name:	image_402961.jpg Views:	0 Size:	499.9 KB ID:	3745439
          Thanks for the tip.
          I tried it, but cant see any difference.
          The screen still flickers between black/blue or maybe on/off.
          This video shows that the red indicator light turns on and off in a random rythm. It reminds me of an old car, that turns, but wont start :-)
          https://www.youtube.com/shorts/_2sv7f1GHpA
ID:	3745709 Click image for larger version
          • Diah
            • Feb 2013
            • 6460
            you need to look on the screen , not on bl or indicator.... however thr result same if you saw or not..... scarp it
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4498
              • Italy - Milan
              what you combined? Both video links do not plays..
              • ulthi
                • Oct 2025
                • 6
                • Danmark
                Davi.p
                I have made a connection on the main board as seen on this image:
                • ulthi
                  • Oct 2025
                  • 6
                  • Danmark
                  Davi.p
                  this is how the tv behaves:
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4498
                    • Italy - Milan
                    Ahi, unfortunately is display panel problem, two blinks is that, search the forum , there are plenty of discussions about it..
                    • JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                      by JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                      Please help. Thanks in advance!
                      08-12-2025, 11:45 AM
                    • Egidio85
                      Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                      by Egidio85
                      Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                      the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                      the fan does not start.
                      I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                      any advice on what to check?
                      06-10-2025, 05:00 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • gbbradshaw
                      Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                      by gbbradshaw
                      Hi.
                      I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                      02-22-2023, 01:31 AM
                    • mar1in
                      Samsung TU8000, backlight and sound on, stuck in blue screen
                      by mar1in
                      I've got this Samsung here that would be stuck in a boot loop.
                      After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                      Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                      Thanks in advance
                      11-08-2023, 05:43 PM
