Westinghouse SK-32H240S Sob story with a Darfon board
  • Tedybear
    • Sep 2014
    • 104
    Re: Westinghouse SK-32H240S Sob story with a Darfon board
    No ideas?
    Trying to understand what's going on with this one. Starts up and fires all the ccfl's without issue. Bad caps replaced.
    Trying to understand the jumbo capacitor test. It's got over 370vdc sitting on one terminal. Just need some direction. Only test I could do with the mosfet's is to compare each leg 1-2 1-3 2-1 etc... Checking to ensure each one does the exact same thing and behaves the same. Not the best test in the world, but the closest one I can think of. (considering the ccfl's are all firing at first? wouldn't a dead mosfet cause the lights NOT to lite up? or am I missing something?)
    S-
    • Tedybear
      • Sep 2014
      • 104
      We are scrapping it for parts. I pulled the main screen off in one piece. Darfon board and the cpu/guts/tuner/all that jazz pulled. We'll list them for parts value (the main cpu works great, the darfon can be stripped for anything needed)
      Much as I do not like it. Beating a dead horse at this stage of the game makes no sense.
      (Plus no one here ever seemed to make it to completion on one of these repairs. I keep seeing hints....direction to follow..and then people fall off the planet.)
      S-
        The one I fixed which is similar setup with 3 transformers, I just had to replace just one bad transformer.
        https://www.badcaps.net/forum/showth...ghlight=SK-%2A
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
