Sharp lc42d64u possible setting issue or bad tuner?
  • whatusername
    • Dec 2013
    • 456
    Hello again.. this sharp aquos LC-42D64U was my personal tv for the last year but i only used it as a additiion to my computer monitor for watching movies and also for playing ps4 both via hdmi.
    Last night when i switched to the 46 i took this to my nephews room so he can use it for a few days till it sells on CL but ran into a problem. i know all components work fine as does HDMI but when he connected his cable box to it via coaxial the picture came up fine but no audio. just a slight almost ear ringing sound and extremely muffled speech at high volume. every tv i fix he runs it thru a rigorous 3 day ps3 marathon and never had this problem before.. is it a setting or does this have a bad Q thingy? the sound display says mono and flashes from green to red and sometimes alternates from mono to sap on its own but no sound just the squeal
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sharp lc42d64u possible setting issue or bad tuner?
    may be
    • whatusername
      • Dec 2013
      • 456
      sound is already set to fixed and stil didnt work.. thanks for the reply though
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        or
        • whatusername
          • Dec 2013
          • 456
          ------>the sound display says mono and flashes from green to red and sometimes alternates from mono to sap on its own but no sound just the squeal<------
          pressing the audio button switches it from mono to sap but it dont stay just makes a quick noise and continues to do above
          • whatusername
            • Dec 2013
            • 456
            well i just replaced the tuner board with another one out of the 46 because they are the same boards and still have same issue
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              which model cable box you use ?
              • whatusername
                • Dec 2013
                • 456
                its a cisco box from ATT Uverse... im over it i just plugged in a HDMI to the cable box and all is well... Maybe these TV"S dont like analog RF cable signals
                • claytongarcia
                  Issue with Sharp LC-42SB45U
                  by claytongarcia
                  I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                  Has anyone dealt with this issue before?​
                  03-10-2025, 07:27 PM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  🛠 Original Issue
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  by ugamazing
                  12-17-2024, 07:05 PM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                • shahnld
                  Lenovo legion 5 pro startup issue
                  by shahnld
                  Good day Experts
                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                  08-24-2025, 12:31 PM
