Sceptre X32BV-FullHD repair
  • DarkManX4lf
    • Sep 2014
    • 3
    Hello. I have a 6 year old Sceptre X32BV-FullHD that just does not want to turn on. This is an LCD display. It has the typical story of it worked fine and then I tried to turn it on again and it wont turn on.
    This TV, while off, has a red indicator led that is always on and the led turns blue when the TV is turned on. The led is not lit at all.
    I've tried all the basic stuff (unplug - replug all devices, try one device at a time, replace power cable...etc) nothing has worked.
    The interesting thing is when I unplug the power supply and plug it back in, the indicator led turns on red for a second and then turns off.
    I've opened the TV and visually checked the power supply's capacitors and there are two capacitors where the tops seem slightly bulging.
    I'm going to order a capacitor replacement kit but was wondering before I do that, is there anything else I should try ?
    I'll post pictures of the TV and its boards when I get home.
  • Shinju
    • Mar 2014
    • 1239
    Re: Sceptre X32BV-FullHD repair
    If this is your power supply, look here http://www.ebay.com/itm/Repair-Kit-S...item4d00c90f33
    this has a list of all the caps to replace in their kit, you can buy their kit or go to mouser/digikey and piece it out and get it a little cheaper.
    • DarkManX4lf
      • Sep 2014
      • 3
      Thanks for the information. However, this is the kit that I would need.
      http://www.ebay.com/itm/Repair-Kit-S...item4cfb6a5c63
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
      • melvinvdb
        Lenovo y520-15ikbm most of the time doesn't turn on
        by melvinvdb
        I've repaired a few laptops in my life but this time my own laptop died😂.
        Funny enough this one is a bit tough on me.
        It doesn't turn on (most of the time).
        Model: Lenovo y520-15ikbm (NM-391).
        The only way to make it turn on is:
        1) unplug battery + charger + rtc (seems irrelevant)
        2) wait a minute
        3) plug battery/charger in
        4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
        5) when it turns on it also displays POST...
        08-15-2024, 12:28 PM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
