can anyone tell me how to do this?
how to test a dlp ballast?
Tags: None
Re: how to test a dlp ballast?
Magnetic or electronic? For magnetic it should be a short circuit. Need an LCR meter to confirm.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
The ballast is the thing the bulb plugs into right? Is there a way i can just put meter progs in there and press power on tv and watch for voltage?Comment
Follow the white rabbit.Comment
First, is the door lamp switch closed ?
There should be about 300V to the ballast and
about 5V lamp_enable signal to make the lamp lit.
Could you hear the ballast arcing ?
Could you hear the color weel spinning ?
No spinning, no lamp_enable signal.Comment
Agree with what was said here. Nealy all sets I have seen--DLP or LCD or even LCOS or DILA--ALL of those with a vapor l;amp--have electronic ballasts. ONE foreign-made one had a magnetic ballast and an "ignitor" module off of it.
You CANNOT safely test the output to the bulb. During 'ignition" that voltage surges to at least 10Kv or higher !! Once a proper arc is established-a MUCH lower voltage--usually under 100 volts at substantial current levels--is then sourced to the bulb--to keep it running.
To properly test one--you need a proper load. A KNOWN good bulb. Then you could tell if it was firing the bulb and then maintaining it. You would also want to know if the input voltage to the ballast--usually 300-385 volts DC, is correct. Some ballasts get the AC from the main PS and then convert it on-board. Also--you need to know if the "lamp on" command is getting to the ballast.
But like said above--if the Color wheel is to coming up to proper speed--the ballast will NOT receive its' "on" command..and no lamp. Check to see if this is ok. And if you see--and/or hear--a "ticking" or "snapping" noise--from the bulb-- after turn on--the ballast is working--and you likely ned a new bulb.Comment
Im new to dlp so I don't know what sounds I'm looking for but when I got it I went to power it on and screen came on and I seen all the fuzz on picture but no light up on screen and green light was blinking lamp and TV went out. So I changed bulb and it still does that. Saying lampComment
samsung hls4266wx/xaa and once i got it i turned it on and i seen fuzz on screen, tv was dark and lamp was not on. So it turned on for 1 sec and then turned right back off so i thought it was lamp and green lamp light was flashing so i thought for sure thats what it was, well it still did same thing when i put new malp in.Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 06:00 PM
This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
This specification for the HP EliteBook 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
- Loading...
