Sharp 46D64u Blinking power light
  • whatusername
    • Dec 2013
    • 456
    Hi guys i picked up this tv that i know i paid way too much for but now its slim pickings since everyone seems to have gotten into tv repair. Any Who this tv has physical damage to the right side bottom of bezel in the form of a hole and split indicating its been dropped on that side and also did not come with a stand. the screen appears to be ok but when i power it up i get a flashing green power light 1 flash every second. if i go to service mode i get a quick flash od the screen where i can see hdmi on the top right then it goes black again with steady light.. i read all the threads on here referring to sharp tv's and am thinking since it dropped it has a few bad ccfl's i do see a couple dim lines on the screen when the quick flash happens. but there was another member who saw the same thing and his issue was inverter boards. so im at a 50/50 cross road and would appreciate some help in diagnosing this.. Thanks in Advanced
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sharp 46D64u Blinking power light
    use CCFL tester http://www.youtube.com/watch?v=sfVkRiDGewA
    • whatusername
      • Dec 2013
      • 456
      i dont have a tester all i have is a dmm
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        what is dmm
        • whatusername
          • Dec 2013
          • 456
          a DMM is a digital multi meter
          Here are a few pics it is very hard to catch the screen on when trying to take the pic
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            please photo near the connectors LA/LB/LC2
              You may have broken lamps. If you roll or move the TV from side to side, do you hear anything rolling inside the panel?
              • whatusername
                • Dec 2013
                • 456
                no i dont hear anything rolling inside ...
                • whatusername
                  • Dec 2013
                  • 456
                  well opened it up and found 4 broken ccfl bulbs.. where the hell am i going to find these things at????? i have no clue
                    I see lots of people here use:
                    http://www.ccflwarehouse.com/
                    • whatusername
                      • Dec 2013
                      • 456
                      thanks for that bud but how am i supposed to know how many mm thick they are? apparently they come in different thickness and i think its something like 1033mm long
                        You mean the diameter. You need one of those digital caliber, that is what I use, good tools to have for checking cap dimension also.
                        http://www.amazon.com/b?node=2476630011
                        • whatusername
                          • Dec 2013
                          • 456
                          lol i actually have 1 of those buried somewhere in my trunk.. the guy i got the tv from has another one same model with a smashed screen on the right side. im sure it probably has a few broken bulbs too but do u think there may be some good ones? he wants same price $50.00 and will not budge from it
                            I am sure there will some good one in there, plus you will have spare boards, so for $50 is not too bad.
                            • whatusername
                              • Dec 2013
                              • 456
                              yea i bought one about 8 months ago same model cracked screen took boards and trashed the rest kicking myself now lol also found out the boards are different in both sets.. and reading the threads here theres also another set of boards so i count 3 different board combos now for the same tv smh
                              • whatusername
                                • Dec 2013
                                • 456
                                anyway i will contact him Tuesday when im off and see if he still has it.. i will update as i go along.. thanks bud.. good night
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  The 46" it's much simpler than my 65". I had the same symptom as you, but I had the master boards replaced and it's working now, but I still have a weird issue with it. It looks like every second tube is not lit up. I can see brighter lines where the tubes are on. I will have to take it apart, to see exactly what is going on, but it is so big and heavy(...and I'm to lazy).
                                  • whatusername
                                    • Dec 2013
                                    • 456
                                    so are you telling me it should have still lit up with bad tubes? i mean mine were broke not just bad. i was under the assumption if u had any bad ccfl's it would go into protect mode like its doing
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      We have different situations. You should get those tubes and see what happens after that.
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        Update: so i picked up the other 46 with smashed screen and found 3 broken bulbs the rest lit up for the half second... i then install 4 of those bulbs into the 46 im repairing and BOOM the tv powered right up. this made me happy.. and Budm u were correct both tv's have the exact same boards in them so now i have all boards as spares and 15 bulbs..
                                        this is now my personal tv and will be replacing my lc42d64u
                                        • FardinAria
                                          asus N552VW version 2.0 HDD light not blinking after bios flash
                                          by FardinAria
                                          Hello
                                          I have Asus N552VW version 2.0
                                          The BIOS file had a problem
                                          after flashing BIOS The hard disk light does not blinking and the caps lock light does not turn on
                                          Please help
                                          10-20-2022, 03:19 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
