Lg 40 inch lcd tv half picture
  • Brass eagle
    Brass Eagle
    • Sep 2013
    • 8
    • Scotland
    I have a LG 40 inch lcd tv when it is on it only shows half the picture on the right hand Side of the screen ( when the tv is on looking at the screen) if you tape the screen or around the sides of it the picture appears fine for a wee while ,I have opened it up and can't see any loose connections ,any help appreciated
  • j0gigs
    • Dec 2012
    • 56
    Re: Lg 40 inch lcd tv half picture
    Its probably the ribbon cables on the lcd panel. Check out this video: https://www.youtube.com/watch?v=xHst6pKLtTE
    It may help.
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • valvashon
      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
      by valvashon
      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
      11-24-2024, 12:08 PM
    • Raulnn
      TD Systems K50DLG12US half black and half white screen
      by Raulnn
      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
      01-20-2024, 04:49 PM
