Vizio VO370M 37" LCD TV Backlights Half Lighting Up
  • 70JUDGE
    • Jul 2010
    • 81
    I have a Vizio VO370M 37" LCD TV that will turn on to the Vizio logo,have sound,but the backlights only light up on the sides for a couple of seconds then go out.The middle part of the screen doesn't fully light up.If you shine a light on the screen,you can see the picture.The Vizio logo is white.This happened during a storm.
    I changed one capacitor on the power board that was out of spec,and when I went to try the TV,I lifted the edge where the stand goes to see if I had a picture,and there was no power.The main fuse was bad.I replaced it,and it went again.I found a shorted MOSFET on the power supply.After replacing that,I am now back to where I started.
    I have tested the capacitors,transistors,transformers,and diodes in the power supply,and they all seem alright
    Can a capacitor measure low ESR,and be low in capacitance?
    One diode on the power supply measures shorted on the board,nothing off the board,but the spot on the board measures shorted.
    Maybe a bulb shorting out on the frame?
    I saw online how you can test the inverters with a cfl bulb.Will a bulb/bulbs from a 17" LCD monitor work,or are they too small,and will burn out?If the bulbs do light up,won't they make me think the power supply is good,when it's not,because the TV's larger bulbs draw more current,and this is causing the lights to not to fully light up because the power supply is not providing enough power?I saw a picture online of backlights not fully lighting up because of not enough power.
    Any help is greatly appreciated.Thank You very much!
    Tyler
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • x_orange90_x
    Replacing backlights in Vizio V755-J04
    by x_orange90_x
    I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
    I have not replaced...
    12-03-2024, 07:03 AM
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • ajshoe
    vizio E60-E3 backlights, sound, no video
    by ajshoe
    Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
    Does this mean remove right side (from front of TV) tabs ?
    Like a second opinion before possibly destroying set....
    04-07-2023, 01:59 PM
