Sansui sled4019 dim picture
  • Hornnumb2
    • Feb 2011
    • 218
    I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael Click image for larger version
  • Hornnumb2
    • Feb 2011
    • 218
    Got it apart, no backlights out hooked backlight tester up and it’s only pulling 52.8 volts. ;there are some bulging caps on the board so gonna go ahead and replace all those. The board has very few voltages listed on it so not real sure what to check. Click image for larger version
ID:	3718737 Click image for larger version
ID:	3718738 Click image for larger version
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4396
      • Italy - Milan
      You bought leds for nothing, there was a cheaper way to do, test first the leds then eventually buy them, the caps havento be replaced, after only after you can continue diagnosing
      • Hornnumb2
        • Feb 2011
        • 218
        I gave $24 for the strips and $25 for the caps I ordered, so not a big expense to get it back up and running. Thanks Michael
        • Diah
          • Feb 2013
          • 6403
          Please show yours PSU Bl circuit from topside and down side too , you seem have sync SMD R Value changed to higher
          • Hornnumb2
            • Feb 2011
            • 218
            Cap kit got it back up and running. Thanks
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4396
              • Italy - Milan
              sorry i do not understand, you recapped whithout changing the leds and tv is back to good state?
              • Hornnumb2
                • Feb 2011
                • 218
                Yes
                • Hornnumb2
                  by Hornnumb2
                  I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
                  08-31-2025, 10:37 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
