55EC930V - ZA Clicking Sound only
  • alltvrepairs
    • Jan 2014
    • 229
    • Malta
    I have this OLED in standby. With remote or local button it tries to start, relay clicks but switches off again immediately. I have noticed 24V dc out missing . But this was due to a missing signal from the mainboard at DRV-ON signal. If I apply 3.5 volts 24v is on but same result. Have disconnected TCON cables one by one but still same issue.
    Is there any mainboard reset procedure or testing please as am new to this model.
    Tks!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4364
    • Italy - Milan
    On main board picture, top of the processor there is a small sot23-6 ic, how it is marked? Is it a reset ic?
    • alltvrepairs
      • Jan 2014
      • 229
      • Malta
      I have uploaded some closeups. The only Sot23-6 IC is marked as HS5NG ic6200. In other posts there are mentions of micro switches on the main board for this model but I cannot find in mine.
      There is a very informative thread here https://www.badcaps.net/forum/troubl...wer-no-display
      Should try the In-Stop trick next.
      Any suggestions more than welcome!
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4364
        • Italy - Milan
        No, it was only a misview, them was only white markings, anyway my doubt was on the standby microprocessor, i wonder why the board picture is 3000x4000 but so very low detail, i cannot name the ic position.. if it is sold already programmed, i would do a try..
        • Diah
          • Feb 2013
          • 6397
          do all steps at the links threat you found..
          Davi.p : stop harming users when you never had or saw OLED TV.. as the other one you fucked it with micro switch..
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4364
            • Italy - Milan
            Don't say stop to me, try to solve some case , i see no cases sol ed by YOU
            OP, yes you can have a problem like the the other thread, good luck, if screen is the problem, i see it hard..
            • Diah
              • Feb 2013
              • 6397
              Don't say stop anytime, you have nothing to stop others , put a good plug of cork in mouth.
              of course i will write always STOP--- cause you didn't answer on the other Parts of comments... "" you never had or saw OLED TV.. as the other one you fucked it with micro switch"" so where i should put the plug at you---- you choose.. front or back doesn't matter for you or !! ASS***LL
              • alltvrepairs
                • Jan 2014
                • 229
                • Malta
                i have tried the In-Stop and In-Start with LG service remote. However the tv screen never switches on. The remote power button works fine and tv responds to the power commands but relays clicks off again after 3 seconds. The optical out red laser never switches on. Usually this indicates main board has powered up.
                Also have read about the microswitches but i haven't found any in my main board.
                Any other tips before giving up please?
                Tks !
                • Diah
                  • Feb 2013
                  • 6397
                  since you have Service remote... did you try P-ONLY (power only) all cable should be in place, keep attention on the screen if it show some things disrupted
                  • alltvrepairs
                    • Jan 2014
                    • 229
                    • Malta
                    Hi again,
                    With the P-ON from remote the screen is lit for a few seconds but a vertical line only is visible. It will eventually go to standby again after around 3 seconds. I have removed Ribbons to screen 1 by 1 maybe I can get the LG logo somehow but didn't manage. Then I put back all connectors and removed the TCON signal cable and P_ON again and the same line was shown. I have checked the TCON for some burns or open fuses but all seemed good.
                    I am inclined to reason a defective panel but has seen wonders in this forum so fingers crossed there are some other procedures I can perform.
                    Regards
                    • B0r1s
                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                      by B0r1s
                      PSU - BN44-00878A
                      Symptoms:
                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                      A weak clicking sound was coming from the transformer.
                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                      Progress:
                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                      01-17-2023, 04:58 PM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • slimmy182
                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                      by slimmy182
                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                      Looking on google I found this:...
                      01-14-2023, 11:55 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Solvik
                      XFX XPS 650w 3XS PSU making Ticking/clicking sound
                      by Solvik
                      Hello
                      i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                      All voltages are normal....
                      02-13-2025, 02:43 PM
