E321VL Powers Up But Backlight Cuts Off
  • 1beertap
    • Mar 2009
    • 219
    Hey Guys, I have this TV that comes on but the backlight will turn off. A flashlight test shows an image on the screen. I can take the third wire from the end called "INV ON/OFF" off of the connector and place it on the pin after the TV is on and the backlight will turn on. Also, I have applied 3.2V to this pin after the TV has been on and got the same results. My voltages are as follows with the TV on:
    VBR_B = 1.51V
    STATUS = 3.31V
    INV ON/OFF = 3.26V
    REMOTE ON/OFF = 3.28V
    12V = 12.13V
    12V = 12.13V
    12V = 12.13V
    GND = 0V TESTED OK
    GND = 0V TESTED OK
    GND = 0V TESTED OK
    GND = 0V TESTED OK
    5.2VSB = 5.25V
    5.2VSB = 5.25V
    5.2VSB = 5.25V
    Any ideas? Thanks.
    Re: E321VL Powers Up But Backlight Cuts Off
    So the backlight stays on if you wire in the BL ON command HIGH?
    • 1beertap
      • Mar 2009
      • 219
      Tom, the thing I don't understand is that the bl_on has 3.26V on it when the termimal is in the connector with the TV on. As I turn the TV on, the backlight comes on briefly and goes out, I disconnect the bl_on terminal and reconnect it and the backlight comes on and stays on, the voltage on this wire stays the same except when the TV is off.
      • 1beertap
        • Mar 2009
        • 219
        I think my problem might be a bad controller chip with part number "0Z9977BGN" Its located on the bottom of the power supply board. I've noticed that when everything is connected, upon turning the set on the backlight will dim down, as if a large current draw exist, and then return to full brightness before turning off completely. Also, the INV ON/OFF voltage drops briefly during this time. My meter is not quick enough to see how much voltage drop. I'm wondering that during this brief time the sensing side is telling the microcontroller to shut down the backlights thus having me to manually reinitialize the backlights at a later time to come on. Any thoughts? Thanks.
        • 1beertap
          • Mar 2009
          • 219
          I upload a video of what this TV is doing. The link is below.
          https://www.youtube.com/watch?v=qwAM...ature=youtu.be
          Hopefully, this clear up some confusion. Thanks.
          • 1beertap
            • Mar 2009
            • 219
            Question: I found a main board that I would like to try but it has part number 3632-1792-0150 (4F) and my board is a 3632-1792-0150 (4E). I know that the difference is the firmware revision, will this matter? Physically the boards look the same.
              Can you try disconnecting VBR_B and connect it to BLON. This will force the backlight to 100%. Some aged CCFLs might not properly light at low intensities.
              • 1beertap
                • Mar 2009
                • 219
                I disconnected VBR_B and connected it to BLON. The backlight lit for a few seconds and cut off.
                  Odd...
                  If you force BL ON directly it works - but will it work if you leave it for, say, 10 minutes after last starting it?
                  • 1beertap
                    • Mar 2009
                    • 219
                    Yes, the backlight does cut off after 10 minutes.
                      So it won't start if left cold for 10 minutes?
                      • 1beertap
                        • Mar 2009
                        • 219
                        I may have misunderstood you. I forced the BL ON directly, after being on for about 10 minutes the backlight cuts off.
                          It goes off after 10 minutes with video source feeding the TV? it sounds like it goes into standby due to lack of video signals, may be not.
                          • 1beertap
                            • Mar 2009
                            • 219
                            I connected a video source, then waited 10 minutes and the backlight stays on. You were right about the lack of a video source then going into standby.
                            • 1beertap
                              • Mar 2009
                              • 219
                              When the backlight comes on for the first time, when turning on the tv, is it supposed to stay on or does it cut off for a second then come back on and stay on? I'm just trying to figure out if the momentary loss in power on the INV_ON/OFF terminal is normal or not. Thanks again.
                                I have seen some TVs do this, it appears normal.
                                • 1beertap
                                  • Mar 2009
                                  • 219
                                  I felt this was normal, is there anything else I can try?
                                    Some does that during the start up.
                                    • 1beertap
                                      • Mar 2009
                                      • 219
                                      With everything connected and turned on these are the readings I get at CN201.
                                      VBR_B = 1.51V
                                      STATUS = 3.31V
                                      INV ON/OFF = 3.26V
                                      12V = 12.13V
                                      12V = 12.13V
                                      12V = 12.13V
                                      GND = 0V TESTED OK
                                      GND = 0V TESTED OK
                                      GND = 0V TESTED OK
                                      GND = 0V TESTED OK
                                      5.2VSB = 5.25V
                                      5.2VSB = 5.25V
                                      5.2VSB = 5.25V
                                      What is puzzling to me is the fact that I have all good voltages but the backlight turns off. Again, I can disconnect and reconnect the INV ON/OFF and magically the backlight turns on and stays on until I turn the tv off. Isn't the backlight supposed to come on with 3.26v on the pin? Anyone?
                                        That is a strange symptom indeed.
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
                                        • jose6326
                                          Samsung s32d850t powers off
                                          by jose6326
                                          Powers on as normal shows an image then powers off after 10 seconds
                                          I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                          No blown caps
                                          I searched for this model but nothing comes up...
                                          11-29-2024, 11:21 PM
                                        • SteveCHS
                                          Definitive BP7006 Plate Amp – Powers On, No Sub Output (Need Help Diagnosing)
                                          by SteveCHS
                                          Hi all — I’m trying to diagnose the plate amplifier from a Definitive Technology BP7006 tower.
                                          Symptoms:
                                          - The amp powers on (red light illuminated)
                                          - No subwoofer output
                                          - Main towers still play normally through my receiver
                                          - No audible hum or noise from the sub section
                                          What I’ve done so far:
                                          - Verified fuse continuity
                                          - Visual inspection: no burned parts
                                          - Confirmed speaker driver reads ~5Ω DCR
                                          - Board ID: LT-C126 (stamped on the PCB)
                                          - Cap glue confirmed factory adhesive, not leakage
                                          - Using a UNI-T...
                                          Today, 09:06 AM
                                        • riki_22
                                          ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                          by riki_22
                                          I’m working on an ASUS B5402CEA notebook.
                                          B5402CEA_MB_R2.2
                                          HA4YT LA-L861P
                                          REV:1B
                                          The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                          I suspect the BIOS might be corrupted.
                                          Could someone please check and clean (repair) the attached BIOS dump?
                                          I’ve also attached a few photos of the motherboard for reference.
                                          Thanks in advance for your help!
                                          11-03-2025, 04:38 AM
