PHILIPS 75PUS7805/12 BLACK SCREEN
  • bohaboha
    • Nov 2012
    • 1031
    • sweden
    Hi all this set power on and the ambient lamps lite but the screen is black and no sound i tried Samsung way to test backlight but it did not work i did also try to power of and hold power for some times nothing happened
    on power supply big capacitor :394v on tcon the 12v and 3,3v even on Mainboard
  • ShaunRutherford
    • Aug 2025
    • america
    Check the cables from the mainboard to the T-Con and from the T-Con to the panel carefully, making sure they are not loose or broken.
    • bohaboha
      • Nov 2012
      • 1031
      • sweden
      ok i ll do a sherlocks investigation on them thank you
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        The "Samsung way" to test the backlight does not work on a Philips. So I guess there is no backlight available? 99,9% the backlight is broken.
        • bohaboha
          • Nov 2012
          • 1031
          • sweden
          do there is any way to be Shure it is a backlight before opening this big beast quite heavy
            • 12331
            • U.S.
            Backlight tester, they are not perfect but very handy for testing backlights, 15 dollars and up at amazon and the usual places.
              • 12331
              • U.S.
              This type is good, more versatile, you can adjust the voltage and current for more accurate testing. It helps to be able to provide more than the typical 30 mA of a lot of the testers which is helpful but not near enough for accurate testing. Specially when working with the bigger screen tvs: https://www.youtube.com/watch?v=7UqAqxJdIDI
                • 12331
                • U.S.
                This example has the better specs and would be more versatile: https://www.amazon.com/SID-LED-Multi.../dp/B07MT87G2P
                  • 12331
                  • U.S.
                  This is the lowest price one I see on amazon with the decent specs, I wish I would have paid the bit extra when I bought one: https://www.amazon.com/Backlight-Mul...=CIHQzb8_tjNJf
                  • bohaboha
                    • Nov 2012
                    • 1031
                    • sweden
                    Hi i have the usual one and as you say they are not not perfect ill try it but not Shure about it
                    • EazyBone
                      • Jun 2023
                      • 1362
                      • United states
                      Did you take a strong flashlight to the screen after you turned it on? Some tvs you'll see a picture.
                      Also what do you mean the ambient light comes on..? Like the led indicator on the TV?
                      But definitely if you fix tvs gonna need LED tester as they say. I got the same one Sony talking about, it's never once failed me.
                      • bohaboha
                        • Nov 2012
                        • 1031
                        • sweden
                        both are on the red led indicator and the light on the back cover around the edge . i did try with my phone flashlight but it is not strong i ll try to find a better one .for the backlight tester i have this simple one and To be honest I don't know how to test this backlight connector see the picture and please tell me how to do it correctly thank you
                        • bohaboha
                          • Nov 2012
                          • 1031
                          • sweden
                          • EazyBone
                            • Jun 2023
                            • 1362
                            • United states
                            Stick black probe where shown in the picture. Each hole is a ground to a specific red. Stick red probe on red line.
                            Make sure power supply is disconnected from clip before testing them.
                            Usually LED tester is safe to accidentally touch probes together also.
                            It will read like 80v (example number) when you have them connected properly. And will show nothing when you have a shorted line or you aren't putting it in the correct red/black pair. So move them around. Experiment.
                            But when the voltage goes to 80 or so you'll see light in the back of tv.
                            Obviously don't do this with AC plugged in
                            • bohaboha
                              • Nov 2012
                              • 1031
                              • sweden
                              'Hi the test black probe on ground (chassis) red probe on red wire =45V step up to 51.5V all of them and there is not a single hole to se the light even with this result it should not light the backlight then i believe i have to get to the backlight it is a big screen and quite heavy set
                              • lotas
                                • Jan 2016
                                • 4880
                                • Russia
                                The backlight is never connected to the common ground! Power + is constantly supplied to the backlight connector, and - (negative) is disconnected, adjustable, controlled by the backlight drivers via mosfets. Here is your connection diagram...
                                • bohaboha
                                  • Nov 2012
                                  • 1031
                                  • sweden
                                  Hi lotas and thank you so my test procedure was wrong then how should i test it black probe to C8622NC and the red probe to VLED+ if I have understood correctly?
                                  • lotas
                                    • Jan 2016
                                    • 4880
                                    • Russia
                                    Yes, red is a common + for all backlight strips, and black is -, for each channel separately (that is, two different -).
                                    • EazyBone
                                      • Jun 2023
                                      • 1362
                                      • United states
                                      Haha yea forgot to post the picture.
                                      • bohaboha
                                        • Nov 2012
                                        • 1031
                                        • sweden
                                        hello again is it yes for my wrong way to test ? then where is the C8622NC i did not find it or please can you point the test point on the picture
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
