I have a Westinghouse SK-32H240S that displays "no signal detected" and goes black. I replaced the main board and the t-con and still has the same issue. I've turned it on in the dark, looking through the back vents and i can see it light up white for a second (something another forum mentioned) so I assume it's not the power board inverter (no caps swollen or any burnt smells) Any advice would be appreciated.
Westinghouse SK-32H240S "no signal detected"
Re: Westinghouse SK-32H240S "no signal detected"
It's important that you understand what I'm asking. I know the screen goes black and you can't *see* the "No Signal Detected" but that doesn't mean it's not there if you look close. You can't necessarily tell an inverter board is bad because there are no swollen caps and/or burning and smells.
If you hook up a source and change the input to it do you get sound ?
