Samsung LED/LCD model UA40C6200U
  • snuggles
    • Aug 2012
    • 5
    • New Zealand
    Hello all,
    My tv won't turn on.Power led solid red when ac supply connected.Starts flashing with audible relay clicking when turned on via remote.
    I have read quite a few threads on here.My question is, with this model /sereis ( C) ,should the backlights come on with the connector lead between the mainboard and power supply disconnected? Or do I need to connect A5v to BL_ON
    Am i correct in assuming BL_ON is a command line, and not a confirmation line.
    Also P_DIM is a led supply dimming command?
    I have checked for backlight operation by connecting LED- to ground,altough not full brightness,all series leds appear to light up.
    The power supply used is a BN4400357A
    I have standby 5v dc stable, and other voltage rails pulsing.Ther is also 160v on the led supply pins.
    I am trying to isolate whether ai have 1 or more faulty boards.
    Thanks,Robert
    Re: Samsung LED/LCD model UA40C6200U
    BN44-00357A has pull-up resistor for the PS_ON and the BL_ON, the transistors on the main board will keep these two signal lines LO, it will release these two line to go HI when TV is ON. So if you disconnect the cables between the main and the Power supply board, the backlights should come on, and the PFC Voltage booster circuits to come on also.
    If you do have backlights then the problem is in the main board is not allow those two signals to go HI.
    • snuggles
      • Aug 2012
      • 5
      • New Zealand
      Thank-you for advice,and the psu schematic. This is also my understanding with the "C" series as well.
      Disconnecting the 18 wire lead from the mainboard and reconnecting the ac supply produces nothing,which would indicate a faulty power supply.
      However, connecting A5v to PS_ON and BL_ON produces backlights and led supply boosted to 188v.Also 12v and another 5v supply present.
      Does this still indicate a faulty power supply?
        OK, I just look at the diagram again, the pull-up resistor (RB852) for the PS_ON is not used, that is why you have to use the external source to turn on the power supply. So it seems to me that the main board is not sending the PS_ON signal to turn on the power supply, it is the main board problem at this point.
        • tibimakai
          • Jan 2012
          • 3680
          I had/have two 46/40C6300 TV's with constantly clicking on and off relays and both had/have mainboard issues.
          • snuggles
            • Aug 2012
            • 5
            • New Zealand
            Thank-you very much for your help.I had read that the mainboard was the achilles heel of this model
            Samsung's policy of only selling replacement parts to their ASC and the price in New Zealand, make this an uneconomic repair.Even with just the main-board.
            Unfortunately the main board appears to non-existant using most search engines
            Power supplies.T-Con seem universal within model ,however main-boards appear to be country/market specific.
            Once again, many thanks.
            Cheers Robert.
            • mmartell
              • Oct 2013
              • 3189
              Maybe a long shot but try heating the main ic with a hair dryer. If it's faulty maybe you can attempt a reflow until a replacement board becomes available.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                09-07-2024, 05:50 AM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
                03-31-2024, 02:12 PM
              • max789
                Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                by max789
                Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                I made the following tests:
                1. Disconnected the main board from Power Board = backlight works.
                2. Connected the main board and disconnected the T-Con = backlights does not work.
                So I ordered a main board from Ebay also BN41-02156A but from...
                01-18-2024, 06:56 AM
