Sony Bravia 55 KDL-55EX640 no backlight / flashes once
  • triplefour
    • May 2014
    • 1747
    got a sony bravia 55 inch LED tv here (first LED tv to fix, and biggest TV ive had yet, also first professional job fixing it for someone else, for money)
    when i first plug it in i get the red standby light. when i push power, the red light turns off, and nothing else happens.
    when i push power AGAIN, the green light finally comes on.
    not every time, but maybe half the time, i see the backlight flash for a millisecond or 2.
    if i shine a light at the screen i can see the sony logo, the menu, etc.
    when i plug the N64 in i can see picture and hear sound but then there is a menu displayed over it saying the tv is in standby mode enabled or something and then it shuts down on its own.
    the sound and picture on the n64 goes out, and after a while it comes back again and then goes out after a second or two. it does this loop a few times and eventually ends up turning off completely. the green light changes to a red light that is blinking. it blinks 6 times, and then stops, then repeats the 6 blinks.
    without anything plugged into it i can navigate the menu screens (using flashlight to see) and keep the picture on for longer until it times out for no signal input.
    anyway i think i have a backlight problem here, and hopefully nothing else.
    i havent taken the cover off yet but will do that soon.
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: Sony Bravia 55 KDL-55EX640 no backlight / flashes once
    ok got the back off... LED tv's dont have inverters, right? they have LED driver boards?
    well i cant find that. i could only find the PSU and the Mainboard...
    i found a connector going from the PSU board that seems like its probably going to the LED driver.
    it has markings that say VLED4+ thru VLED4-
    but those wires seem to go directly into the panel itself.
    not sure what to do here...
    • holmzy
      • Nov 2009
      • 99
      check all smt fuses on psu
        The LED driver power supplies are on the top left side of the power supply board, you can see 8 grey caps and 8 diodes for 8 strings of LEDs, that is what I think you have.
        The connector on the top right has voltage labels for it, what are the voltage on each pins when TV is OFF and when TV is on, make sure to give each pin name and voltage.
        You may have either open or shorted LED sting that causes the LED power supply to go into shutdown.
        Service manual:
        http://elektrotanya.com/?q=showresul...oria=&kat2=all
        • triplefour
          • May 2014
          • 1747
          ok it is a 15 pin connector, with one pin (pin 13) not connected
          v_off is with the set plugged in, red stby light on
          v_on is with the set plugged in, green light on
          pin# name v_off v_on
          1 3.3vstb 3.3 3.3
          2 ACD 2.9 2.9
          3 Pwr_on 0 3.3
          4 audio12v .5 12.9
          5 audio12v_gnd 0 0
          6 reg_12v_gnd 0 0
          7 reg_12v_gnd 0 0
          8 reg_12v .15 12.9
          9 reg_12v .15 12.9
          10 BL_ERR 0 3.3
          11 BL_ON 0 3.3
          12 PWM Dimmer 0 1.27
          13 NC 0 0
          14 TconVcc12v 0 12.9
          15 Tcon_on 0 3.26
          as for surface mount fuses on the power supply i dont see any but the one main fuse, and its fine.
          voltatges, to my limited understanding, seem correct?
          • triplefour
            • May 2014
            • 1747
            great. it formatted away all my spaces
              OK, looks like you have all the correct signal, the only signal I do not know is the BL_ERROR, not sure if HI (>2VDC) is good, or <1V is good. I did not download the service manual yet to look at it in details.
              • triplefour
                • May 2014
                • 1747
                yeah i would like to know that too but i cant find any service manual out there..only the useless "user manual"
                where is the good resource for all the service manuals?
                edit: nevermind i found it
                • triplefour
                  • May 2014
                  • 1747
                  not sure what to make of what they are saying in the manual about 6 blinks because the conditions under which i have to put the tv to make the 6 blinks are different. they are talking like just when u turn it on, it flashes for a second then turns off and goes to 6 blinks. mine doesnt do that it turns on to green and the screen flashes. the only way i get 6 blinks is if i have my n64 plugged into it to actually give it a signal... then it does weird things... ill try it all again and see if i can get a better idea of whats happening
                  and it seems like it only flashes once after its been unplugged for a while and the first time i try it
                  • triplefour
                    • May 2014
                    • 1747
                    yes its really strange. if i have the n64 plugged in and switch to the channel its on, then it plays the sound for a second (and if i hold a light i can see the image for a second... ok maybe 2 seconds) but on top of the image is a menu that says something about idle mode and that its going to turn off...i cant read it because its really dark and its too quick. the picture and sound go off but the green light stays on. after about 5 seconds the image and sound comes back, and disappears again. it goes through this loop maybe 3 times before it shuts down with the 6 blinks error code...
                    the service manual is pretty useless. it doesnt mention what BL_ERR should be, and the pages where it does mention it, its giving it a different pin number than i have on my board so i dont even know what board they are talking about
                    • triplefour
                      • May 2014
                      • 1747
                      well im stumped....little help anyone?
                        Since you do have 6X code which indicate as backlights error. You can see if one of the wires to the LED string inside the panel is shorted to the metal panel or not, remove the LED connector from the board and then check each one of the 8 pins against the chassis to see if it shows any resistance.
                        • triplefour
                          • May 2014
                          • 1747
                          ok i see infinite resistance on all pins to the chassis (a screw holding the psu board in)
                            OK, so the wires are not shorted to the chassis, next thing can be that one of the string has open circuit or one of the power supply for one of the string is not working.
                            What you can do is to monitor each one of those pin during the power on sequence to see if they all act the same way with regarding to the voltage readings on each pins, set the meter 200VDC scale and check each pin during power on cycle, may be one or two will show some abnormality.
                            • triplefour
                              • May 2014
                              • 1747
                              what should i use for ground ref during this test?
                              • triplefour
                                • May 2014
                                • 1747
                                ok i just went ahead and used the chassis screw on the psu for ground ref and i found that on pin 1 of CN3 and pin 1 of CN4 i get usually much higher voltages than the others.
                                behavior at power on time is like this:
                                0v when red stby light
                                0v when green light goes on
                                few more seconds pass
                                voltage present at same moment of backlight flash
                                voltage quickly drops to zero as im reading it
                                voltage remains on the other pins
                                reading the voltage on the remaining pins eventually zeroes them all out as well.
                                waiting a while does not bring the voltage back
                                only turning off and repeating the cycle brings the voltages back
                                they voltages vary with each test but pin1 of each CN3 and CN4 seem to have the highest voltage at around 60v but ive seen it as low as 40 and as high as 100
                                the voltages on the other pins are usually between 15 and 30v but they vary a lot from test to test.
                                probably my meter cant get an accurate reading since they immediately drop as i measure them.
                                heres the breakdown of the test where i held the red probe to the pin as i started up.
                                CN3
                                pin#---voltage
                                1---74v
                                2---33
                                3---24
                                4---21
                                CN4
                                1---42
                                2---17
                                3---15
                                4---26
                                and i did another test where i didnt measure anything as it was starting up, i waited till after the flash and then measured the voltages present as they dropped to zero. i repeated this test 4 times and wrote down the values.
                                i did more testing than this but i couldnt write everything down.
                                CN3
                                pin1 pin2 pin3 pin4
                                68,26,10,18
                                62,16,26,18
                                69,22,27,12
                                47,21,17,18
                                CN4
                                pin1 pin2 pin3 pin4
                                56,25,27,24
                                100,27,24,24
                                92,17,17,15
                                66,18,29,17
                                one thing i seemed to notice was that when i got the higher voltages, it coincided with a brighter flash. it flashes really lightly sometimes. i could only tell from looking at the back. and even then just barely. other times it flashes quite brightly. but always just for a moment.
                                anyway hope this tells you something. i wont try to guess what it all means. i got voltages on all pins thats all in know...
                                • triplefour
                                  • May 2014
                                  • 1747
                                  so...any ideas?
                                    OK, I found picture of your board at shojimmy, it looks looks like it uses 4 strings of LED instead of 8 as I thought, there are 4 pairs of LED + and - as labeled at the connectors.
                                    Can you take good clear pictures of the bottom side of the board so i can clearly how the connections are made around the LED connectors and the transformers (2) and those 8 didoes and caps close by? Too bad the service manual does not have any diagrams.
                                    If I have to guest, I would say reading of 100V on CN4 PIN1 represent open LED string.
                                    Do you know how to use your meter in DC AMP mode?
                                      This is how I check to see if I have open LED strings, using AMP meter in series with the feeding wire of the LED string to see which one does not draw any current.
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        ok heres the pictures of the board. sorry i cant get a good one of the whole board right now because my camera sucks, daylight is fading, and apparently i just dont understand lighting for circuit board photography well enough.
                                        but i managed to get a good shot of the part you were talking about.
                                        as for testing with my meter in amps mode i can safely say i have never done it. if you can explain clearly which probe to put where though, im sure i will understand it afterwards.
                                        • JUCaESAl
                                          Sony bravia KD-65AF9
                                          by JUCaESAl
                                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                          10-20-2025, 04:03 AM
                                        • thstuff
                                          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                          by thstuff
                                          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                          01-30-2023, 05:01 PM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                        • Dangerousk
                                          Sony Android TV KD-49XE9005 4 red flashes
                                          by Dangerousk
                                          Hi there
                                          Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
                                          Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
                                          thanks
                                          D
                                          10-27-2024, 06:10 AM
