Sony Bravia 55 KDL-55EX640 no backlight / flashes once
    Re: Sony Bravia 55 KDL-55EX640 no backlight / flashes once
    OK, that is pretty well focused pictures, I will have to download and trace out the connections and draw up simple diagram to see how the LED strings get the power to them. So wait until tomorrow when I have more time.
      BTW, what are the DC A scales do you have on your meter? Can I see the picture?
      • triplefour
        • May 2014
        • 1747
        heres my voltmeter
        Don't fear the repair...
          OK, put the meter on A DC 10A scale, you will have to move the red probe to the 10A socket, too bad your meter does not have 2A scale, hopefully it is sensitive enough to see some action on the meter.
          You will have to cut the wire one at time on the connector CN3, the wire should be cut so you can splice the wire back together.
          You can start by cutting the wire on CN3 PIN 1, then strip the wires so you have expose conductors, then you will put the meter probe on each expose conductor, you should wrap the conductor on the probe tip and tape it up.
          Then turn one the TV, if the LED string does not have open circuit you should see the reading jumps up before it goes into shutdown. You will have to do the same on the other 3 wires as well to see which one show no action on the meter.
          As you can see in my picture, I use clips for making connection, the reading on my meter shows around 300mA, your meter may show something like 00.2 or 00.3. BTW, do not worry about the probes polarity.
          https://www.badcaps.net/forum/showth...t=25810&page=5
          • triplefour
            • May 2014
            • 1747
            ok i am about to do this. should i do this for CN4 as well?
            oh wait i think i get it now... cn4 is all the negatives only
            • triplefour
              • May 2014
              • 1747
              i just tested cn3 pin1 and i didnt see anything happen on my voltmeter. even when i put it on 200ma
              • triplefour
                • May 2014
                • 1747
                i didnt want to cut any wires so i figured out this way of doing it instead. i just removed the wire from the harness and wedged the probe in there
                and then used a bit of wire to splice the other probe to LED wire. i used my other meter to test continuity between the black probe and the pin to verify they are indeed touching.
                but on pin1 and pin2 of CN3 i still see no activity on my meter in 10a or 200ma
                the only thing i noticed is sometimes the negative sign flashes for a moment on my meter
                  The negative sign is just telling the direction of the current flow, what we are looking for is the inactivity of current flow when the circuit has open connection due to bad LED that has gone open circuit in the LED string, the protection circuit monitor the current flow through each string and maintain the constant current flow to give steady backlights, if the LED goes open circuit, the voltage will rise, then the protection circuit will shutdown the LED power supply.
                  • triplefour
                    • May 2014
                    • 1747
                    well i only tested pin 1 and 2 but they both seemed inactive. either that or im not measuring it right? could they both be open?
                    can the LED strings be changed or repaired?
                      You may want to read this thread:
                      https://www.badcaps.net/forum/showth...TRIP%22&page=4
                      • triplefour
                        • May 2014
                        • 1747
                        im reading and trying to understand but a lot of whats in this thread is over my head....
                        am i going to have to open the panel and take out the LED strips?
                          Yes, just enough to see which LED strip does not light up to narrow it down first, but if you never take the LCD panel assembly apart before you can easily damage the screen.
                          Unless some body else has better ideas.
                          This might work, you can have just one of the four wire connected and see which one does not show a flash of backlights for seconds, you should observe it in dark room.
                          • triplefour
                            • May 2014
                            • 1747
                            yes i will try that first. i REALLY dont want to take this panel apart. its HUGE and its a clients TV and if i damage it i cant afford to replace it.
                              I avoid taking the panel apart myself unless I have to also.
                              • triplefour
                                • May 2014
                                • 1747
                                ok after testing and re-testing, i cant seem to get any reading of amps with my meter. i have concluded that the pin1 and pin2 are not lighting up the backlight at all though. pin3 and pin 4 by themselves or together, always light up the backlight for a flash.
                                pin 1 and 2, together or by themselves, never flash the backlight.
                                but since i cant tell whats going on with the current, how do i know if its the LED strip or if the pin is just not supplying the current? i can tell it supplying volts but i just cant read the current for some reason, on any pin!
                                • triplefour
                                  • May 2014
                                  • 1747
                                  can i switch the wires so that pin 3 and 4 lights LED strip that was plugged into 1 and 2 ?
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    ok after doing a BUNCH of wire swapping and testing ive noticed a few things:
                                    the wire sequence for CN3 is
                                    pin/color
                                    1-white
                                    2-white
                                    3-black
                                    4-blue
                                    im to beleive that each of these wires powers a different LED strip but i cant see it for myself since i didnt open the panel yet.
                                    anyway first i tried each wire by itself. found that both white wires on pin 1 and 2 dont produce any flashing of their LED strips
                                    i found that the black wire (pin 3) and the blue wire (pin4) both produced backlight flashes. but the blue wire was noticeably dimmer of a flash.
                                    also if i keep turning on and off the TV, the blue wire's flash eventually gets dimmer to the point where u cant even see it anymore.
                                    the black wire (pin 3) gets a little dimmer on the second flash but then remains the same brightness on future flashes and i can turn it on and off many times. it never becomes dimmer than on the second flash.
                                    so then i moved on to switching wires around.
                                    i tried the black wire on each of the pins
                                    on pin 1,2, and 4 it would flash, but dimmer than on pin 3, and repeated flashes would get even dimmer until you just cant see it. maybe 2 or 3 times before u cant see it anymore.
                                    the blue wire does a similar thing on all pins but overall just dimmer than the black wire.
                                    the white wires do nothing no matter which pins u plug them into.
                                    i am having trouble guessing what is going on here? why does it get dimmer on successive flashes with all but the black wire on pin 3?
                                    why do the white wires do nothing? are both of those LED strips completely failed?
                                    if the black wire's LED strip is fine (since its the best performer), then why does it shine dimmer on the other pins, and eventually not even flash at all?
                                    too many variables
                                    also can i even order replacement LED strips, or do i have to replace the LED's themselves?
                                      I trace out the board, yes each one of those are for each LED sting (4 strings), the wires are connected to each Anode of the each LED string, the return wires on the CN4 are the Cathode side of each LED string.
                                      I say 1 (white) has open LED/s in that string. You can have more than one failed string.
                                      At this point since it is customer's unit, I would inform them that the TV needs new LCD panel, if they let you keep it then you can use it as learning tools to how LED panel functions and you can take the panel apart to see what are inside.
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        cant i tell them i can take a chance at replacing the LED strings?
                                        and how can i be sure that its bad LED strings and not a bad converter?
                                        • Clydeuk
                                          • Jan 2012
                                          • 193
                                          #40
                                          I would tell them the truth, that you believe the LED strings have failed, that if they take the set to a repair shop they will receive a quote/bill for a new panel. Then tell them that if they are prepared to risk damage that you are willing to investigate repairing the panel. Just let them know the risk involved so that you don't get lumbered if the panel does get damaged, since a new panel is the normal course of repair here.
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • thstuff
                                            SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                            by thstuff
                                            This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                            Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                            1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                            2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                            01-30-2023, 05:01 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • justin35
                                            Sony bravia kdl-43w755c - boot loop
                                            by justin35
                                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                            from what i read online it looks to be an emmc issue…
                                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                            i took out the board and say an samsung 16gb emmc
                                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                            i could try to put one instead of the 16gb one, but will it work?
                                            where do i get the software from?
                                            any help will be much appreciated!...
                                            03-06-2024, 12:26 PM
