Brown gook on board
  • kevinm34232
    • May 2012
    • 1884
    Brown gook on board
    What is this and what's the best way to clean it up?? Can it cause problems?
  • mariushm
    • May 2011
    • 3799
    Re: Brown gook on board
    It looks like flux to me.
    You can leave it there or remove it with isopropyl alcohol
    • kevinm34232
      • May 2012
      • 1884
      It doesn't come off very easy with alcohol and a Q-tip, it's hardened but does come off in smooth areas with enough rubbing.
        Try using Q-tip and Acetone.
        • Glitcher
          • Mar 2013
          • 673
          • USa
          Its usually fine, I've seen it on most of the main boards I've salvaged from Samsung panels.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            Flux is pretty low on the list of things causing problems. It's not impossible, but it would have to be a very sensitive circuit.
            -David VanHorn
            • kevinm34232
              • May 2012
              • 1884
              Is it safe to "dip" the board in Acetone, and maybe scrub with a tooth brush? Is there any need to use alcohol after to remove residue or will it evaporate?
              • mariushm
                • May 2011
                • 3799
                Acetone can attack the plastics on capacitor and other components, or dissolve the printed text on various components.
                I would advise against it, especially as it doesn't really look like you need to clean it.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
