Gentlemen, I have another Samsung Plasma (MY older Brother's) that I would like to save from the scrap heap. I started by turning on set. It has stand by red led on, plays a little tune for start up, sound comes on shortly after , but no video. Removed back and started checking every thing for visible damage, could not find any. I started checking the voltages on the power supply as per label. Va. 55v, Vs.211v, Vsc.-198v, and Ve.89v My readings were,Vs.9.75v, Va.3.6mv, Vsc.0v, could not find Ve voltage on board. I then checked CN802 to logic board. pin 1 05.3v, my reading 5.2v. pin 2 05.3v my reading 5.2v pins 3-4 are gnd. pin5- ps-on my reading was 0v, same with Vs-on, 0v . I then proceded to connector CN801 to main board Ps-on 0V , STBY 5.1V GRND 15v- my reading14.6 v All readings on this connector were ok except PS-on 0v. I started to disconnect one board at a time with no change to power supply voltages. I also did the test to main logic board, by shorting pins 3-4 to try and get test pattern, no luck. I'm thinking I'm stuck at this point, so any help would be appreciated on where to go from here. Pictures can be viewed on http://rccrasher65.imgur.com There are 10 pics in album. If you can't view please let me know, as I can still not load pics here for some reason, when I see everybody else having no problems. Its probably just me though. Thanks in advance for all the help. George
Samsung plasma PN50C550G1F/ Sound, no picture
Tags: None
Re: Samsung plasma PN50C550G1F/ Sound, no picture
My main logic board has no blinking led lights also. Does anyone know where I can get the service or repair manual for this set. Thanks again,George -
for test pattern,you need to unplug the big ribbon cables that goes to the mainboard as well as jumper pin 3-4.Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/Comment
You will also sometimes need to jumper PS ON signal to GND.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
In this case, it will only be the LVDS cable.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Tom, I have no PS-ON voltage, 0V On CN801 all voltage's check out, except PS-ON - 0V On CN802 i have 5.2V , 5.2V , gnd, gnd, PS-ON 0V, VS-ON 0V. On CN 804, both VS read 9.75V, they should be 211V, gnd, 15v reads 14.65V, gnd, VA. 3.5mv or 0V depending on what meter I use. one is autoranging, one is not. VA voltage should read 55V. VSC -198, and reads 0V, VE 89V could not find this on any board. I'll try test on main logic again, to see what happens. there are no led lit on this board. thanks again for all your help.Last edited by rccrasher65; 08-15-2014, 11:47 AM.Comment
Tom, I did that the first time, only thing is pins are not marked, not sure what pins are 3-4. I did the bottom two looking straight at the tv, assuming pin 1 is at top left of board. I'm also using an alligator clip to short pins as they are too close together. should I try something different?Comment
It's usually the top two pins. However you cannot cause any harm if they are in the wrong place - it will just switch to a different mode.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, I will give that a try, how do you jumper PS-on, like you say. With the vs and va voltage's basically missing will this test work. I found a diode, giving me voltage in both directions.Its DB803 in center of PS. I also checked some fets, got OL on two on all pins, not very sure I'm doing this right but , if you could explain, I know I could do it. You can check these in circuit, can't you. My DVM is a klein MM200 ,auto ranging. I did some research on reading fets, but I still don't understand what setting to put meter on. In diode mode I can press the function key and read V or press again and read resistance, not sure what one to check fets in. Thanks again for all the help guys!Comment
I have the same tv that I could not fix
I changed the psu, logic and x main boards
Tom even helped me test it with an o-scope
The only thing that I didn't replace wad the main board and the lower buffer boards
Hopefully you have better luck then I did
Here is my thread in case it might help
https://www.badcaps.net/forum/showthread.php?t=28943Comment
Thanks Jose, I did read through your thread, Why didn't you fix, was it not worth it, I don't want to throw money into this one, but I have a source for all new boards for it for $75.00, also I like to learn, so i'll try with everybody's help. My problem is a little different. I have no VA voltage, and only 9.75V on Vs. No pic, but sound. just hope it isn't the panel. Thanks for all your info. GeorgeComment
RC on the Logic board (pic4) right above the Samsung SD1 logo and arrow are 2 led's marked led2000 and led2001 with r2152 separating them. Led2000 should blink once per second when set is powered on, this indicates normal operation, once every 5 seconds indicates a fault.
I am currently trying to repair a pn60e550 set that has a different logic board than yours but has the same led2000 indicator but no led2001. When I first started T/Sing my set the led on mine would not blink, had to replace logic board.
Not sure yours has same problem as mine but just saying. I am fairly confident logic board controls VE and Vscan voltages but cannot confirm thru searching. VE voltage test point is usually on the X Main board, Vscan test point is usually found on Y Main board.Last edited by MagicSmoke; 08-16-2014, 08:35 PM.Comment
Like Tom has indicated to get VS and Va volts on PSU to come up jumper PS-on to GND and VS-on to 5.3v. This is w/ both CN801 and CN802 cables unplugged from every thing.
If VS/VA volts don't come up or are unstable or low/high then it's safe to say PSU has a problem. The test points are indicted on the PSU
If VS/VA come on and are stable and close to panel sticker values then the problem lies elsewhere. You won't get VE or Vscan with X&Y boards unplugged though.
My set has similar problems as yours, will power on w/button/remote can hear beeps when volume pressed up/down but no display or faint glow on panel.Last edited by MagicSmoke; 08-16-2014, 08:40 PM.Comment
Magic Smoke, thanks for all the info, i'll try this on sunday evening. what connector do you use to jumper PS-ON, and VS-ON. I tried the test by disconnecting LVDS cable , and jumpering the two top pins on Main logic board, with no results. My main logic board has no visible led lights flashing at all when powered up, dead. Thanks again, George I also found a bad diode on PSU, DB803 I think, I'm not looking at my set right now. It's giving voltage in Diode mode in both directions.Last edited by rccrasher65; 08-16-2014, 10:13 PM.Comment
To confirm if DB803 is bad, can you supply a photo of it, or the part #?
Try unplugging X and Y-main boards with your jumpers in place, do you get Vs & Va?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I cannot see the legend on the other side of CN801 and CN802 in your pic of PSU, the wires are covering.
My PSU only has 2 connectors for power, yours has 3.
On mine PS-on and VS-on are on the same connector, in my case CN804. Pin 1&2 for PS-on and GND with pin 4&6 for VS-on and 5.3v.
Yours might be different. The legends will indicate which pins to use.
Disconnect all 3 power wires from other boards for this test. This will tell you if PSU is generating the proper VA and VS voltages. Then you can proceed in testing other parts.
DB803 on my PSU reads voltage in both directions with meter in diode mode also and it is generating correct voltages when jumpered on.Comment
Gentlemen I didn't get a chance to do anything with my set today. I will get on it Mon morning. Tom, I will get pic of diode, and try to read part # I will also load up closer photos of psu. What connector do I do all this jumpering On. Should I remove the diode and check it out of circuit, to be sure if its bad or not. I always thought diodes as having voltage flow in one direction, and if it flows both ways its bad.Comment
The connector you are jumpering links the power board and the main A/V board; the main A/V board has the video inputs on it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Thanks tom, i'll get those pics loaded, I can't see the writing on diode so I'll take it out, and check after I do this test, will post results soon.Do I have to disconnect the ribbon cables from the bottom of y,x main also to do this test or just disconnect the power to y main. My x, and y are connected together. Just want to make sure before I do this, don't want to do any more damage, Thanks All.Last edited by rccrasher65; 08-18-2014, 07:11 PM.Comment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by DodgethisHello all,
This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...5 Photos - Loading...
